Wiper motor problems - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 18th, 11, 09:37 PM Thread Starter
I am working on getting my wipers working on my 70 RS after 25 years. I got the motor to run in both speeds and the pump to work. the problem I am havin it will not stop when I turn the switch off. If I unplug the connector off the switch they go to the home position and stay until I plug it in again. Sounds to me its the switch. Any other suggestions? Also how do you get the shaft out ofthe light switch. the knob comes with a new shaft on it and I have no idea how it comes apart. Any suggestions
mhaseleu03 is offline
post #2 of 4 (permalink) Old Mar 18th, 11, 09:43 PM
Re: wiper motor problems
No help on the wipers.
To get the knob out of the headlight switch - feel around on the switch behind the dash and you'll find a small spring-loaded button. Pull the knob all of the way out(headlights on), then press on that little button and pull the shaft out of the switch.
BPOS is offline
post #3 of 4 (permalink) Old Mar 19th, 11, 05:52 AM
Kevin
KevinW's Avatar
Mike, the motor base plate needs to be grounded for the park circuit to work. Usually a brass tab that goes under the top most grommet. This is for a 69, hope 70 is the same!
Kevin
KevinW is offline
post #4 of 4 (permalink) Old Mar 19th, 11, 09:48 AM Thread Starter
Re: Wiper motor problems
Thanks for the info I will try this today.
