Backup Switch Location on Muncie 4 speed - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 24th, 11, 05:22 PM Thread Starter
Can anyone tell me the location of the backup switch on a 69 Camaro Muncie 4 speed with Hurst floor shift. Can't find anything in the AIM's manual or under search this forum.
jabeyers is offline
post #2 of 7 (permalink) Old Mar 24th, 11, 06:32 PM
Dan Ensign
Re: Backup Switch Location on Muncie 4 speed
Back up switch is on the steering column connected to a rod from the reverse lever on transmission.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #3 of 7 (permalink) Old Mar 24th, 11, 06:42 PM
steve
the backup switch is under the dash on top of the column at the lower end it is white with a pink and green wire.
stevie is offline
post #4 of 7 (permalink) Old Mar 24th, 11, 09:08 PM
Daryl
1968RallySport's Avatar
Jim, here's the switch location just like Dan & Stevie said. It's operated with some linkage you may be missing.
Name:	1969 backing lamp switch-001.jpg
ID:	21408   Click image for larger version
Name:	1969 m20-001.jpg
1968RallySport is offline
post #5 of 7 (permalink) Old Mar 24th, 11, 09:22 PM
Jerry R.
jr68's Avatar
What if the Muncie was added later ?
and you dont have the linkage going to the column.
Is there another way to actuate reverse lights ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #6 of 7 (permalink) Old Mar 25th, 11, 12:18 AM
Larry
larryh56's Avatar
Yes, you can put a switch on the trans that is operated by the linkage when you shift into reverse. Then you just wire that into the backup light circuit. I think I got one several years back from Hurst. This is what it looks like: http://www.rickscamaros.com/camaro-4...1967-1969.html
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #7 of 7 (permalink) Old Mar 25th, 11, 07:58 AM Thread Starter
I am missing the linkage rod from tran to lower lever of steering column rod. I had to tie down the upper column lever to release the key lock because of that. We know this is a transmission conversion. So it sounds like my best option is the transmission switch that Larry mentioned.
Will check into it.
jabeyers is offline
