How much and who to go to for wiring AAW ? - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 26th, 11, 09:07 AM Thread Starter
TONY
i live in atlanta ga. and like to know how much for someone ( ball park#) to wire up my 1969 camaro convertible its a bare shell iam going to use AAW kit the updated one and also do anyone know of someone who can iam willing to travel up to 8 hrs to get done thanks
from1964impalass is offline
post #2 of 9 (permalink) Old Mar 26th, 11, 10:09 AM
Cruzin "the 82"
angelglo's Avatar
Re: how much and who to go to for wiring AAW ?
Tony, im sure you can wire up the camaro yourself inside of the round trip travel time. it is fairly simple. you can save time and money doing it yoursellf as these kits are user friendly
angel
angelglo is offline
post #3 of 9 (permalink) Old Mar 26th, 11, 03:47 PM
randy
classic industries and use there coupon
icemanrd19 is offline
post #4 of 9 (permalink) Old Mar 26th, 11, 04:02 PM
Aaron
BigDawgDavao's Avatar
I agree on doing it yourself. Just need a good set of crimpers and you're pretty much good to go with those kits. I would recommend you go to the tech support/wiring kit instructions and search for your kit #500686. Then download the various diagrams to have a look at how well it's documented step by step. If you have a bare shell already running the wires would be a snap. You also gain a healthy knowledge of your electrical system for future potential problems.
BigDawgDavao is offline
post #5 of 9 (permalink) Old Mar 26th, 11, 05:29 PM
topher
69 383 tko 5sp's Avatar
I dont think we have answered your question. Most members are probably installing the kit themselves and are speaking from experiance when they say its not very difficult. That being said, it will depend on your skill level and attention to detail(crimping,routing,ect). I'm sure somebody will chime in that has paid a shop to do thiers. I am in the middle of installing the same kit and if you choose to do it yourself, take Aarons advice and get the correct crimpers. Also, dont forget to pick up a couple rolls of the non-adhesive electrical tape.
69 383 tko 5sp is offline
post #6 of 9 (permalink) Old Mar 26th, 11, 06:03 PM Thread Starter
TONY
naw guys i dont want no parts of doing it myself and having my car looking like fred sanford did it i will leave it to the pros but paying $1600-2200 is nuts ! the most i think it should be is $600-1000 at most i know someone out there can help get me to the rigth guy
post #7 of 9 (permalink) Old Mar 27th, 11, 06:23 AM
Andrew
Andrew69's Avatar
Re: How much and who to go to for wiring AAW ?
Tony- What is the plan for your car? Is it Pro-Touring with everything updated, is it back to original throughout, or somewhere inbetween? If original, purchase the original wiring design and you will simply plug everything in, no crimping required. Each socket is unique and will only plug into the one part it is designed to power.
At this point, if it is a bare shell, there isn't much more to do than to lay the wiring in the right places. When something is installed you plug it in
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #8 of 9 (permalink) Old Mar 27th, 11, 09:51 AM
X2 on what Andrew wrote.....wiring harness selection depends on the build type....if you're going back to stock......AAW's Factory Fit line of wiring harnesses are what you need.....Pro Touring or Resto-Mod.....AAW's Classic Update wiring harnesses are what you'll need and they'll require some crimping of connectors whereas the Factory Fit harness is "plug & play" as Andrew stated earlier.
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #9 of 9 (permalink) Old Mar 28th, 11, 06:40 AM
Prodigy Customs (http://prodigycustoms.com/) is in the Orlando Florida area, about 7 hrs away from you. They can do the job for you with their eyes closed. Give Frank a call and see what he says. He is often on here helping out and is a sponsor of Team Camaro as well.
Jim & Yvonne
1968 Camaro
468 BBC, Turbo 400, 4.10 12 Bolt.
2010 Camaro SS/RS, Black on Black Leather
2008 GMC Crew Cab 4x4, LMM Duramax, Allison 6 Speed,
6" Cognito Lift, 35" Nitto's
Ledfoot is offline
