Car wont start No spark - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 30th, 11, 01:03 PM Thread Starter
I have been at this for 3 weeks now. I have a 69 camaro with a 350. It has the msd 6al box and the hei ignition. I dont know if im over lookign it or what. but I get no spark to the plug. I have checked and the msd box is hooked up right and I replaced the cap rotor and coil. I parked it in the garage came out the next day and nothing.
Motor does turn over and its getting fuel if anyone can offer me any help or just tell me how to hook up the hei distributor without the msd box that would be great too.
If your in the central florida area I will pay someone knowledgable to come and repair this for me.
Thanks for your time.
blackphantom is offline
post #2 of 6 (permalink) Old Mar 30th, 11, 03:48 PM
Re: Car wont start No spark
You can hook up the HEI dist if you still have the module to install back into it. Unhook the MSD harness to the HEI pick-up coil and connect pick-up coil to the HEI module. Spread some heat sink grease on the bottom of the module for transferring heat. You can get the grease from Radio Shack or local auto parts store.
Apply a full battery voltage to the HEI dist BATT terminal from within the fuse panel IGN spade using #12 wire.
Use a timing light to check for spark and time the dist to the engine.
post #3 of 6 (permalink) Old Mar 30th, 11, 04:47 PM Thread Starter
I did buy a hei 4 pin ign module and put that back in the dizzy fly problem is I know u hook the 2 wires that's inside the dizzy to the ign module but idk what wires are suppose the hook up to the 2 other pins or where those two wires go. When it comes out of the distributor.
post #4 of 6 (permalink) Old Mar 30th, 11, 06:09 PM
Look here: http://rmcavoy.freeshell.org/HEI.html
The module plugs into a connector assembly/harness inside the body, then the same harness coming out plugs into the the terminals closet to the cap, those further inside BATT & TACH to connect to the coil.
Include the spring and button inside the dist cap to connect the coil output to the rotor.
post #5 of 6 (permalink) Old Mar 30th, 11, 06:16 PM
Page 16 at this link...http://www.msdignition.com/uploadedF...0_instructions
68 Camaro~LSx ~all motor
post #6 of 6 (permalink) Old Apr 1st, 11, 07:34 PM Thread Starter
So I hooked up the hei. Batt to the battery and the two wires out of the dizzy plugged into the ground and yellow wire on the hei. But still nothing.
