Auto meter electric oil pressure gauge - Team Camaro Tech
post #1 of 18 (permalink) Old Apr 3rd, 11, 03:05 PM Thread Starter
Jon
Small block 388 running a electric oil pres gauge. Started car and gauge was at 60. noticed during slow cruising was only 20 psi. Brought rpm up to 2500-3000 and no change. Could it be the sensor?? I hope. Got home shut down and cooled, restarted and 20psi.
JR67RS is offline
post #2 of 18 (permalink) Old Apr 3rd, 11, 04:47 PM
Hector
Re: Auto meter electric oil pressure gauge
Could be the gauge or sensor... Did you get on it, any engine noise?..ground out the gauge see if does a full sweep...try loosening the sensor and retighten..if that fails to show any improvement... You would need to get a mechanical gauge to confirm...oil pressure...
I would doubt it's an engine issue because if it were I would venture to say you should still see a change in pressure either from increased rpms or cold start..
Speedjester is offline
post #3 of 18 (permalink) Old Apr 3rd, 11, 05:01 PM Thread Starter
Jon
Thanks hector. No engine noise. Going to plum in a mechanical gauge and confirm. Boy I hope thats all it is. Only 35 miles on it.
JR67RS is offline
post #4 of 18 (permalink) Old Apr 3rd, 11, 05:25 PM
Hector
Check with a mechanical gauge... If it still reads low I would guess either a broken or stuck open pressure relief spring in the pump...
post #5 of 18 (permalink) Old Apr 3rd, 11, 05:28 PM
Russ
Did you put thread sealer on the sender unit when installing it ? Possibility some of the sealer made it's way into the sender. I had this happen once when installing a sender with motor in the car.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #6 of 18 (permalink) Old Apr 3rd, 11, 05:40 PM Thread Starter
Jon
I did use tape. I wondered myself if it got clogged up.
JR67RS is offline
post #7 of 18 (permalink) Old Apr 3rd, 11, 06:10 PM
Hector
I always thought those switches work on ground resistance.. Wouldn't the tape interfere with the grounding..
post #8 of 18 (permalink) Old Apr 3rd, 11, 06:11 PM Thread Starter
Jon
Hmmmm. Good question. I'll have to scope it out.
JR67RS is offline
post #9 of 18 (permalink) Old Apr 3rd, 11, 06:20 PM
Hector
From what I understand the electronic pressure gauges work off ground resistance...when I help my buddy install an electric sensor in his firebird it specifically stated not to use anything on the thread.. As it could effect the gauges..
post #10 of 18 (permalink) Old Apr 3rd, 11, 06:26 PM
My Autometer fuel gauge frequently sticks on E - a flick with a fingernail always wakes it up. Sticky needle I guess.
BPOS is offline
post #11 of 18 (permalink) Old Apr 3rd, 11, 06:31 PM Thread Starter
Jon
Hector i will check this. if it is ground what should i use to keep it from leaking at the threads?
JR67RS is offline
post #12 of 18 (permalink) Old Apr 3rd, 11, 06:38 PM
Hector
I thought they were pipe thread and tapered.. The further they twist in the tighter the seal..when I did my buddies just threaded it in by hand then threw a wrench on it and tightened it up good.. No leaks..
post #13 of 18 (permalink) Old Apr 3rd, 11, 10:25 PM
prostreet69camaro's Avatar
I use liquid teflon on my sending units. It is a white paste.
I dont use teflon tape. With liquid teflon you still get a good ground on the sending unit.
prostreet69camaro is offline
post #14 of 18 (permalink) Old Apr 4th, 11, 08:25 AM
Russ
Agree with Mike, I use PTFE (teflon) paste on all my senders and never had a ground problem as the paste does conduct electricity.
Russ (RJ)
rj68RS is offline
post #15 of 18 (permalink) Old Apr 4th, 11, 05:03 PM
Hector
So what's the word?
