Fuel gauge problem please help. - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 9th, 11, 04:58 PM Thread Starter
Tim
For starters I'm kinda new to this forum so thanks for your help in advance.
Okay, I have a 67 camaro and my fuel gauge is not reading accurately. When the tank is full it only reads to a little over half full. To be exact, on the gauge, the needle reads to the beginning of the "L" on the word "FUEL" on the gauge itself.
Before you answer, here is what I already did. I actually have 2 other fuel gauges that I tried and they read in the same exact way so I don't think it is the gauge itself. I did replace the in tank sender a few years ago, while I was restoring the car, but I never checked it with the gauge to make sure it was reading accurately. Is it possible that the float in the tank needs to be bent? Has anyone had an issue like this?
Is it possible that a wire on the sender is wrong that would create this issue too?
Any help would be appreciated. thanks.
Tim
Shady350 is offline
post #2 of 13 (permalink) Old Apr 9th, 11, 05:35 PM
Jon
Re: Fuel gauge problem please help.
Did you check your ground near the tank?
JR67RS is offline
post #3 of 13 (permalink) Old Apr 9th, 11, 08:34 PM Thread Starter
Tim
I could check it again but I did reattach it to where it was originally attached.
If not attached properly is that what will happen?
Also anymore responses will help too. Thanks
Shady350 is offline
post #4 of 13 (permalink) Old Apr 9th, 11, 10:02 PM
Kurt
camsdad's Avatar
There may be spring from a old style fuel station nozzle rolling around in the fuel tank.
It happened to me. If I remember right it was about 5 or 6 inches long and about 1" diameter and every once in awhile it would roll onto the fuel sender float and give me false fuel gauge readings.
I actually found it when I dropped my fuel tank during my resto-mod.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #5 of 13 (permalink) Old Apr 10th, 11, 08:38 AM
Jon
Are you using a stock gauge or autometer?
JR67RS is offline
post #6 of 13 (permalink) Old Apr 10th, 11, 08:52 AM
Alan
Isn't the easiest thing to do to disconnect the fuel gauge at the trunk lock connector and test the gauge with key on by grounding and ungrounding the lead to the gauge? That will at least tell him if the gauge is correct. If the gauge tests OK, I would be looking real hard at the sender.
alan
alanrw is offline
post #7 of 13 (permalink) Old Apr 10th, 11, 09:17 AM
Bob
If two gauges provide the same reading, it sounds like a bad sending unit- or bad wire to the sender. In all likelihood though,the float has developed a small pinhole leak,which has allowed fuel to enter, thus preventing it from going through the full range of motion and reading full. Drop the tank, install a new sending unit,and the problem should be solved. It's not a ground,because if it were, the gauge would likely read nothing at all, or full at all times.
BelAirBob is offline
post #8 of 13 (permalink) Old Apr 10th, 11, 09:57 AM
prostreet69camaro's Avatar
I would disconnect the wire for the sending unit in the trunk. Then turn the key on. With the wire disconnected it will read past full.
Next ground the wire that goes to the guage and then the guage will go to empty with key switch on.
This will check the guage and the wiring from the trunk.
If this works then its the wire to the sending unit or the sending unit.
prostreet69camaro is offline
post #9 of 13 (permalink) Old Apr 10th, 11, 06:16 PM Thread Starter
Tim
Okay, that's what I needed. A bunch of answers to try to figure this thing out.
To answer some of the questions,
It is NOT an auto meter gauge. It is an original gauge.
Just to clarify, The fuel gauge does move as the gas gets used in the tank but it only goes to where I stated before when I completely fill it. As it gets used up it does go down and seems to read properly when it's nearly empty.
I'll check the ground wire as some of you suggested and if that doesn't work I guess I will have to drop the tank, unwillingly, to check the sender itself. The float filling with fluid is an interesting thought. Has anyone else had this happen? With my luck that's what it will be. After all, the sender is only about 2-3 years old and never has worked correctly, so maybe it was defected right from the beginning.
Shady350 is offline
post #10 of 13 (permalink) Old Apr 11th, 11, 03:56 PM
Eric
Thats exactly what happened to mine. I bought a Spectra premium sender two years ago. The hollow plastic float got a pin hole in it and sank. Also the sender filter had fallen off. Pretty dissapointing after spending $87.00 on it. Mine was so bad all it would do was read empty all of the time. I hate to say it but Ford sells really nice brass floats for $14.00,it works great now.
L30 327 is offline
post #11 of 13 (permalink) Old Apr 13th, 11, 04:34 PM
The float is some kind of hard plastic foam stuff, It's not hollow and I've never seen one get saturated and sink. Check your wires, connectors and grounds.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #12 of 13 (permalink) Old Apr 14th, 11, 05:30 PM
Daniel
Hi Shady350,
I concur with L30 327, I also had the same problem as you have.
On my 1st Gen, I purchase two bad new repro sending units (giving bad readings) that I finally change for a Spectra Premium Sending Unit P/N FG104C (3/8 Single Line) that I purchased from NAPA.
Good Luck,
Daniel.
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
FBODY is offline
post #13 of 13 (permalink) Old Apr 14th, 11, 11:57 PM Thread Starter
Tim
L30, thanks for the in site on that I will try the wires and all but it seems the float has happened to more then one person here so maybe it's more common than I thought. Btw, where did you get the ford float and how did you mount it on.
Fbody, thanks for your experience too. It seems that L30 even had an issue with the spectra one, but I think that is gonna be the one I get anyway since it seems a little better quality. Oh and I think the one I need is 104B not C. I'm gonna say you might have a 69 camaro? I noticed there are 4 part numbers 104A is for 5/16 and 104B is for 3/8 for 67 when I checked. It seems that 104c came up for a 3/8 when I used 69 for the search. I don't know why but that is just what I came across.
Thanks again all. It's always great to hear from many to brainstorm on something. But I am still interested in that brass float idea L30.
Shady350 is offline
