Temp. gauge problem - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 10th, 11, 02:22 PM Thread Starter
craig
Temp. gauge problem
69 Camaro with gauge package.Problem is when i turn the headlights on the temp. gauge pegs itself on hot.Happens with car running or not.All new wiring harness' from M&H.Any ideas? Thanks
willard is offline
post #2 of 9 (permalink) Old Apr 10th, 11, 03:09 PM
Brad
Re: Temp. gauge problem
Bad ground. Most likely in the gauge pod area. You say new harness? Main harness? I would back track your grounds on that to. You'll be surprised what one bad ground will fix.
Most recent 01/01/10
spideynut is offline
post #3 of 9 (permalink) Old Apr 10th, 11, 03:23 PM
Jeremy
I agree with this. Definitely a bad ground. Like said above, it is probably around the gauge. Check and make sure you cleaned off all paint when you attached all your grounds. A ground needs to bond to clean metal to make proper connection.
67 Camaro
makoshark is offline
post #4 of 9 (permalink) Old Apr 10th, 11, 03:27 PM
Kris Boutilier
Temperature guage should have 2 wires, one hot 12 V one signal wire and ground comes from enclosure. It almost sounds like your hot 12 V is tied into your lights and is hooked up where your signal should go. Take a volt meter and see if your 12V hot switches on and off with your lights. If so you have wrong hot. Also switch signal and hot wire and see if guage still pins.
I just rewired my 1967 camaro and my temp guage is pinning too. I think I also have the hot and signal on wrong terminals. Going to fix later this week when I get back home.
1967 RSSS is offline
post #5 of 9 (permalink) Old Apr 10th, 11, 05:02 PM Thread Starter
craig
It's a single wire sender.396/375.Also my fuel gauge reads 1/2 when it's full. I'll check my grounds again. Thanks again
willard is offline
post #6 of 9 (permalink) Old Apr 10th, 11, 10:17 PM
Jeremy
So does the gauge housing act as a ground?
67 Camaro
post #7 of 9 (permalink) Old Apr 11th, 11, 08:24 AM
Jeremie
The gauge housing on my 69 acts as a ground. Mine has one ground that is coming from the gauge attached to the gauge housing, and another ground from the harness attached to the gauge housing.
MTN10 is offline
post #8 of 9 (permalink) Old Apr 11th, 11, 10:52 PM
cb
Send a message via Yahoo to flyingskibiker
The factory console temp gauge has two wires. The Pink wire is the power. The Dark Green wire is from the sender. The sender varies the resistance to change the gauge reading.
One set of the gauges (2 "pods" with 2 gauges each) is tied to the other via a jumper wire. Then, another wire from the harness is connected to the gauges and the transmission tunnel for grounding all the gauges.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #9 of 9 (permalink) Old Apr 12th, 11, 09:37 PM
Brad
Yeah! What he said.^
