67 low fuel module / light ???? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 13th, 11, 12:52 PM Thread Starter
Bruce
Does the low fuel module require a light bulb? Mine has a socket for a push in bulb but I see no place for it to "light up" in the console. I do have the light in the dash which works when 12 volts is applied to the yellow wire from the module without a bulb in the module.
RAGMARO is offline
post #2 of 4 (permalink) Old Apr 13th, 11, 01:45 PM
Re: 67 low fuel module / light ????
No, nothing goes in that socket.
Ron
The ď
Ē
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 4 (permalink) Old Apr 13th, 11, 04:03 PM
click's Avatar
Bruce, as Ron said, nothing goes in that socket. The same GM part was used across many lines of Chev. Pontiac, Buick etc. some used a bulb, some didnt. Camaro uses the light in the dash above your left knee instead but the socket/sending unit is still needed to send that signal to the dash light.
click is offline
post #4 of 4 (permalink) Old Apr 13th, 11, 07:31 PM Thread Starter
Bruce
Thanks!
RAGMARO is offline
