Looking for terminal/junction block - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 14th, 11, 06:36 AM Thread Starter
Mitch
Lost in the 60's's Avatar
I'm in the process of rewiring my car and am looking for a terminal stud/junction block/buss bar to run power from. I'd like something protected from accidental shorts. I like the one Madd Electrical has on their website but I can't get a call thru to order a handful. Anyone have a similar product that I can get ordered soon ? I'm about at the point where I need this in the next week.
...38 Chev coupe, street rod
...54 Chev 210 coupe
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...69 C10, cab and clip may end up on the '89 rollback
...70 Chevelle SS, Canadian documented Z25 project
Lost in the 60's is offline
post #2 of 10 (permalink) Old Apr 14th, 11, 06:58 AM
Steiner
Re: Looking for terminal/junction block
How much power do you need on each feed? The parts stores carry little Cooper Bussman ATC fuse blocks that will hold six 30A fuses. They've got a stud on them where you connect your power feed and then six male spade connectors that are only hot if you have a fuse inserted.
http://www.autozone.com/autozone/acc...ier=32322_0_0_
AutoZone and the like can also get these:
http://www.autozone.com/autozone/acc...er=603354_0_0_
Also if you want to come straight off the battery the parts stores have a nice little stand-off type deal by the battery cables that replaces the nut on your battery cable clamp. You screw it on and then it has a stud on the end where you can mount multiple ring terminals.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 10 (permalink) Old Apr 14th, 11, 07:21 AM
Greg
Fry's electronics has the isolated buss bars. I bought one "just in case" I ever needed it.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #4 of 10 (permalink) Old Apr 14th, 11, 07:37 AM Thread Starter
Mitch
No big power requirements, just swapping to a 10si alt, getting the cabin power off the horn relay and running the headlights direct thru relays. The Cooper fuse panel looks interesting and I wouldn't need fusible links then either... I'm gonna run that by my electrical engineer friend and see if he likes it. It would be easy to mount to a panel and hide in the fender similar to a '67 rs headlight center.
Thanks !!
post #5 of 10 (permalink) Old Apr 14th, 11, 07:50 AM
Steiner
I used a couple of them. Original stuff still comes across the horn relay but I replaced the fusible link with circuit breakers. Then I ran a new 60A fused cable through the firewall and under the console to one Bussman block for full time power. One of the full time legs of that one feeds a relay which is ignition keyed to supply power to the other block. Anything added to the car is run off either of those.
I used an AGU fuse and holder at the battery for the new power feed like this:
http://www.allelectronics.com/make-a...HOLDER//1.html
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 10 (permalink) Old Apr 14th, 11, 08:09 AM
Ed
BigBlock1969RS's Avatar
Back awhile ago when ordered a bunch of stuff from Mad, Mark didn't have a lot of his nice junction blocks, and was only bundling them in kits. I found them for a bit more on Corvette Central. American Autowire and Rock auto used to carry them but stopped.
GM Part number is #340409, I think its discontinued.
$14.95
http://www.parts123.com/parts123/yb....~Z5Z5Z50000050
Also I think the alternator boots from AAW make nice covers for this block:
http://shop.americanautowire.com/alt...minalboot.aspx
Ed
BigBlock1969RS is offline
post #7 of 10 (permalink) Old Apr 14th, 11, 08:16 AM
Russ
Any place in your area that sells/installs the 10 gillion watt boom box stereos in rice rockets and Escalade's will have terminal blocks like you want.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #8 of 10 (permalink) Old Apr 14th, 11, 12:50 PM
I bought a couple of these with great plans to use them - just haven't gotten to it yet. Can be found on the web for about $10/ea. http://bluesea.com/category/9/35/products/2314
BPOS is offline
post #9 of 10 (permalink) Old Apr 14th, 11, 01:52 PM
http://shop.ebay.com/i.html?_nkw=jun...d=p3286.c0.m19
68 Camaro~LSx ~all motor
post #10 of 10 (permalink) Old Apr 19th, 11, 04:54 PM
Rick
70's and 80's gm trucks have a straight junction block on the firewall with 5 studs for connections. It's similar to the round one in post 6 but it has multiple studs all connected together. Really cleaned up my wiring for my headlight, fan, and alarm relays.
RickH is offline
