Friends 67 having electrical issues - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 22nd, 11, 01:10 PM Thread Starter
Ed
I just got a call from a friend who's having issues with his 67. It has a non-original engine in it and my guess is he's got some wiring issues. He's had issues with the car not cranking over at all.
Here's what he told me:
1) he replaced the starter
2) he replaced the battery
He says that he also checked to see if the car was drawing current when just sitting and that it was not (I will verify this tomorrow when I see him).
He says that if he trickle charges the battery to the point of "the green light saying it's charged" when he tries to start the car it seems to discharge the battery "really fast"
So my guess is, given what hes said, it's either the battery or when he's in the process of trying to start the car there is a short.
Here's what I plan on trying:
1) I told him to trickle charge the battery tonight with it disconnected from the car - we can see if it starts
2) I will take the battery out of my 68 and see if that starts the car
Any ideas how I can check to see if there is a short somewhere when the car is trying to start?
Any other ideas?
Thanks in advance!
Ed
emdoller is offline
post #2 of 10 (permalink) Old Apr 22nd, 11, 01:28 PM
Dan Ensign
Re: Friends 67 having electrical issues
It sounds more like a bad battery cable or ignition switch. Perform a voltage drop test with a digital multi-meter on both positive and negative cables. Check for 12 volts from ignition switch at the starter solenoid.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #3 of 10 (permalink) Old Apr 22nd, 11, 02:39 PM Thread Starter
Ed
Dan E.
Thanks, I'll give that a shot.
What's strange to me as that he claims that battery goes from charged to not being charged quickly. I find that hard to believe even it there is a short. I also don't know how he comes to that conclusion other then his car wont start and he hears clicking. Should be a fun thing to debug!
One other thing that was interesting is he said that a puff of smoke came out of the battery.... something I've never ever seen... while he was trying to start the car
Ed
emdoller is offline
post #4 of 10 (permalink) Old Apr 22nd, 11, 04:51 PM
Usually a puff of smoke is from the cable clamp and battery post being dirty and the current drawn is creating heat across the resistance. Wire brush both items on posts.
Do the same to the other ends of the cables and attach the ground to the block.
test light between a disconnected cable and battery post will show the current drawn and light filament will limit the amount of current drawn. Bright light means significate amount of current drawn. Little brillance means a reduced amount of current drawn.
Might have to view in darkness. Modern electronics will draw a miniscule amount for memory & clock.
post #5 of 10 (permalink) Old Apr 22nd, 11, 07:00 PM Thread Starter
Ed
Thanks. I wonder if his voltage regulator / alternator is putting out too much voltage? That might explain him smoking the battery. He took it back this evening and they gave him a new one.
Ed
emdoller is offline
post #6 of 10 (permalink) Old Apr 22nd, 11, 07:14 PM
VR could be set too high, always a possibility.
post #7 of 10 (permalink) Old Apr 23rd, 11, 07:45 AM
JAY
Greetings from Arizona
is this a new install or just a problem that came up?
if new install its recheck all wiring for proper connection and clean connections
also check engine to make sure it infact does turn over!
let us know what you find....
few years ago there was a new tool released to mechanics, Its called POWER PROBE! It is the best electrical tester I've ever used, you hook it up to battery on both power and ground....with its 20 foot cord you can test anywhere on the car without looking for good ground. and you can test both power and grounds at same time. I carry one in my car everytime I go out of town to car shows. handy if anyone has electrical issues and needs tester. Good Luck Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #8 of 10 (permalink) Old Apr 23rd, 11, 05:19 PM Thread Starter
Ed
It's hard to tell if it's a new problem or not because he just bought the car.
Today we put in a new battery and cables. I also saw that his alternator was a 32A which is underrated for a car with AC. I happen to have a 61A rebuilt one so we put that in as well. Car started up right away as expected. Only time will tell if we solved the problem.
emdoller is offline
post #9 of 10 (permalink) Old Apr 23rd, 11, 05:44 PM
Glad you got it running and all should be normal.
You will probably measure charging voltage across the battery posts and this is a good thing. But, how much charging 'current' is the battery receiving? Kind of like a water-saving faucet, lots of line pressure (voltage), but very little flow (current) due to the orifice in the faucet head. Somewhere between the alt BATT stud and battery post, and ground side also, could be some resistance in the wiring and/or teminals or a broken crimp to reduce current flow.
Harbour Freight sells a cheap 50-0-50 ammeter for around $10 or 50% off with coupon, then $5, and you can insert it between the positive pigtail and junction block for test. Battery will draw close to 30-40 amps right after using the starter, then level off. Over 15-20 minutes, might draw 5-8 amps depending upon charge originally.
post #10 of 10 (permalink) Old Apr 24th, 11, 06:16 AM
click's Avatar
While you fiddle with elec. gremlins, go buy a Wells VR715 regulator, most parts houses carry them, they are electronic replacement for the old style points regulator. The original cap even fits over it... this will confirm your regulator doesnt have issues too.
click is offline
