Sense of Humor Failure - Harnesses!!! - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 25th, 11, 03:01 AM Thread Starter
Tim
Hey all, Happy Easter!
Mrs. ZLP955 came down with the 'flu, so Easter visiting family became Easter at home
Decided to use the time wisely and try to understand wiring harness requirements. I have no engine compartment wiring remaining, all the rear wiring has been cut and the under-dash stuff is incomplete and very brittle, so I'm planning to re-wire the entire car with all new wiring harnesses.
Then I discovered that trying to interpret the subtle differences between wiring harnesses is indeed a Dark Art.....
What are the references to "warning lights" in certain harness descriptions? Are these the in-dash colored warning lights? If so, why would a front light harness refer to warning lights?
http://www.rickscamaros.com/camaro-f...ghts-1969.html
Especially since the engine harness also refers to "warning lights":
http://www.rickscamaros.com/camaro-e...ghts-1969.html
Some under-dash main harnesses refer to warning lights with console shift, and others refer to factory console gauges but no mention of warning lights.....
The 1969 factory wiring diagrams only refer to "warning lamps" for the Corvette, for "Door Ajar", "Headlamps Up" and "Seat Belts".
I am now very confused and am hoping that someone can explain these differences to me - thus avoiding a sense of humor failure!
Do I need to lock myself away for a day with the original wiring diagrams to understand it? Is there a harness 101 class??
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #2 of 11 (permalink) Old Apr 25th, 11, 06:39 AM
parkbrau's Avatar
Re: Sense of Humor Failure - Harnesses!!!
Because in the front engine harness you have temp and oil sensor and possibly tach if your car came with tach. Those will feed to the idiot lights on the dash if it is none console gauge car. If car has gauges on console then those wires will feed to the console gauges.
Did I make it any worse?
Bottom line. Do you have a factory tach? Factory console gauges? Or just use the idiot lights on the dash. WHat exactly do you have for gauges? Or what do you want to have?
parkbrau is offline
post #3 of 11 (permalink) Old Apr 25th, 11, 10:12 AM
^^ X2 ^^
It's just that simple. The console gauge option slightly changed the wiring requirements, both under the hood and under the dashboard. "Warning Lights" was the basic package. (TEMP, OIL, etc) under the gauge pods.
BPOS is offline
post #4 of 11 (permalink) Old Apr 25th, 11, 08:38 PM Thread Starter
Tim
John & Al,
Thanks for your replies, I get what you both said but I'd like to clarify before ordering parts. What the car has (or once had!) is this:
Instruments in dash carrier: speedo, center clock, factory tach.
Factory console with factory gauges and 4spd shifter.
No A/C, non-RS car.
As I understand it, I will need these main types (am not including misc stuff like heater harness, fan harness, center clock harness etc). I have used links to Ricks site just as examples:
1. Front Lighting Harness.
For cars with gauges (http://www.rickscamaros.com/camaro-f...uges-1969.html)
2. Engine Compartment Harness.
For V8 cars with gauges (http://www.rickscamaros.com/camaro-e...uges-1969.html) OR for V8 cars with gauges and carb solenoid (http://www.rickscamaros.com/camaro-e...noid-1969.html) How do I know if I have a carb solenoid? Is this for electric choke? (I have a 780 Holley 4053).
3. Main under-dash Harness.
For cars with manual console shift and factory console gauges (http://www.rickscamaros.com/camaro-u...uges-1969.html)
4. Passenger Compartment/Rear Lighting Harness.
A dash-to-quarter harness (http://www.rickscamaros.com/camaro-d...oupe-1969.html) and a standard (non-RS) rear lighting harness (http://www.rickscamaros.com/camaro-r...dard-1969.html)
So any references to "warning lights" on harness descriptions is for standard cars that didn't have console gauges, and if I use the above parts I will still have the necessary connections to my dash colored warning lights for overheat, brakes, high beam etc?
Guys, TIA for your help, I just don't want to order the wrong parts as it will cost me time and big $$ to return them from overseas....
ZLP955 is offline
post #5 of 11 (permalink) Old Apr 26th, 11, 07:19 AM
That's how I understand it, Tim! What I'm not sure of - and I'm sure someone knows - is....did the factory console gauge cars still have the gen,oil & temp warning lights?
My take on the carb solenoid - I've always called it an "anti-dieseling" solenoid. It was mounted on the driver's side of the carb and was meant to close the throttle blades when you shut the car off to prevent run on. I think!! My 307 PG no-AC car had one. Anyway, the wire going to it is a "key on" 12v wire and is pretty handy to have. For example, if you're running an electronic ignition that doesn't call for the resistor wire, it's a good source for that, although you'll have to come up with your own connector.
BPOS is offline
post #6 of 11 (permalink) Old Apr 26th, 11, 03:01 PM
Brady
I am in the middle of rewiring mine now and would like to know that answer too. My biggest roadblock was when I realized I needed a volt meter (additional $125) instead of the ammeter because I purchased the American Autowire upgrade set. My biggest aggrevation has been cutting the wires and putting the connectors on, figured for that price they would be pre-installed. It is good that my son does this, cause I would have broken something by now.
By the way, does Rick's Camaros sell American Autowire?
Anybody know where the courtesy lights go, been a while since I have seen them, now I cannot remember where they go!!!
dirtlover is offline
post #7 of 11 (permalink) Old Apr 27th, 11, 03:25 AM Thread Starter
Tim
Hopefully somebody who knows one way or another can clear this up for us. I'm sure there would be a connection for the in-dash "idiot lights" on a gauges car because (as far as I know) the factory console gauges don't have any specific warning function, and the gauges are notoriously difficult to see from a normal driving perspective anyway.
I couldn't find anything on the web site to confirm who supplies the harnesses that Rick's sell, but the American Autowire site does list Rick's First Gen as a dealer of their products (searched for dealers in GA).
I think the wiring for the under-dash courtesy lights feeds out from the kick panel (at least on a '69 coupe) with orange/white cables, but if you are asking whereabouts the actual lamps were positioned below the dash, sorry I don't know, hopefully someone who has them can post a pic or dimension. May also be in the AIM?
ZLP955 is offline
post #8 of 11 (permalink) Old Apr 27th, 11, 03:28 AM Thread Starter
Tim
Thanks for your reply Al, hopefully someone will clarify for sure. Interesting point on the carb solenoid, hadn't thought of that possibility. I'll do some research on the Holley model that I have.
ZLP955 is offline
post #9 of 11 (permalink) Old Apr 28th, 11, 10:42 PM
cb
Send a message via Yahoo to flyingskibiker
Since you said "manual" shift console, I assume you have a 4-speed. So, you won't have a solonoid mounted on your intake/carb.
I wouldn't worry too much about weather you will have warning lights with the gauges harnesses. American Auto Wire usually gets it right. So, if they are supposed to be there, they will be. 69s are different, but 68s don't have warning lights for GEN and OIL if gauges are installed. Just BRAKE and (low) FUEL warning lights. While helping another person on here, it does seem that 69s have warning lights even with gauges. I would just buy the AAW harnesses and go with what they have and is more than likely correct...
Rick's and everyone esle sells AAW. AAW is pretty much the go to harness vendor for all the parts houses... Factory Fit is AAW's direct replacement harnesses. AAW Update harnesses have the blade fuses and maintain the factory colors and options. But I believe those kits one has to do crimping, etc. Factory fit, with original style fuses has all the correct connectors already installed. So, one just pulls out the old and pops in the new. OK, maybe not "pop"...
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #10 of 11 (permalink) Old Apr 28th, 11, 11:29 PM
That solenoid wire would also be a good power source for an electric choke.
BPOS is offline
post #11 of 11 (permalink) Old Apr 29th, 11, 03:25 AM
Brady
AAW Update harness is what I went with. The bulkhead connector is a plug and play, but had to cut and crimp for the engine compartment, front lights and rear lights, etc. Once that is done, just plug it all together. The big thing that threw me was the voltage regulator, but past that now. The other is the courtesy lights, trying to remember where they go and realizing there is one on the console too. This is a pretty good kit though and you have plenty of extra wire left over.
