Keep Blowing Fuses - Team Camaro Tech
post #1 of 5 (permalink) Old May 1st, 11, 07:18 PM Thread Starter
Keep Blowing Fuses
I need some help troubleshooting a blown fuse issue. I installed an AAW Classic Update wiring harness in a 67 Camaro. All works fine except the 5A fuse labled Guage keeps blowing. When the fuse blows the tach, volt meter, and choke stop working. I'm using a MSD 6AL. Any ideas as to what could cause the fuse to blow?
Rod
rarobins is offline
post #2 of 5 (permalink) Old May 2nd, 11, 03:07 AM
Re: Keep Blowing Fuses
Choke should be wired to another source.
The correct source, I can't say as I have no references here with me.
post #3 of 5 (permalink) Old May 2nd, 11, 07:22 PM Thread Starter
OK, I will check the wiring diagram.
rarobins is offline
post #4 of 5 (permalink) Old May 2nd, 11, 08:14 PM
prostreet69camaro's Avatar
I would disconnect the choke wire and see if it still blows the 5amp fuse. The choke is probably overloading the circuit.
prostreet69camaro is offline
post #5 of 5 (permalink) Old May 4th, 11, 09:03 AM
Put a test lamp in place of your blowing fuse and start disconnecting pieces of that circuit until the lamp dims. The test lamp acts like a current limiter and gives you visual feedback, not to mention being cheaper and safer than feeding it fuses.
dnult is offline
