68 with idiot lights - Team Camaro Tech
post #1 of 16 (permalink) Old May 9th, 11, 04:09 PM Thread Starter
Harvard
I've been going in circles trying to get what wires were original to a 68 with idiot lights in the front light harness. The AIM and chassis service manual diagrams have a mix of idiot light and gauge set ups. I'm looking for what came on the car from the factory in a few important places. Long story short: I put in a console conversion harness to fix the wiring that was hacked up for the console. Then I found the console wasn't original and now I have to un do what I did and am going to put in the idiot light pod. That part is easy, but since I didn't have the car when it had idiot lights, I don't know what wires only go for the idiot light set up. I've got most of it figured out but need help in a few areas:
1) I need to know if the white wire coming off the alt. turns into an orange wire with a fusible link as the AIM shows before it goes to the VR. Or if it was originally white all the way from the alt. to the VR. One other person said theirs was white but their harness was kind of hacked up.
2) The AIM shows a pink wire going from the terminal farthest to the right on the VR to the bulkhead connector. I have a brown wire in this position and assume this goes through to the dash and then to the GEN warning light. One other person has told me their wire is brown also, but I would like to confirm if someone else has an untouched harness they could look at and is this position D-U on the bulkhead connector?
3) The AIM shows an orange fusible link wire connected to the junction block behind the battery that turns into a black wire that goes to the bulkhead connector and then another orange fusible link that has a black wire with a white stripe that goes to the horn relay and then to the bulkhead connector. These are ones I added in the kit for the AMP gauge for the console and were not on the car. Are these not needed for an idiot light car?
If anyone has an original car or harness that could help I would greatly appreciate it. I have a week of vacation coming up and I would like to get this all back at that time.
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate.
68zproject is offline
post #2 of 16 (permalink) Old May 9th, 11, 09:06 PM
cb
Send a message via Yahoo to flyingskibiker
Re: 68 with idiot lights
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #3 of 16 (permalink) Old May 10th, 11, 03:26 PM Thread Starter
Harvard
Originally Posted by flyingskibiker View Post
Thought I'd get more traffic over here. I can't believe no one has an original 68 with idiot lights. This wiring diagram BS is driving me crazy.
post #4 of 16 (permalink) Old May 10th, 11, 04:59 PM
cb
There should be people here that have done it all. Watch, once the replies start, there will be a ton. I know another guy here made his own schematics. I forget if they are for gauges or not. Again, I modified the schematics based on my new harnesses...
post #5 of 16 (permalink) Old May 10th, 11, 09:06 PM Thread Starter
Harvard
I've got tons of different wiring diagrams, but I can't gt those three items above nailed down. None of them show lights only. I saw some laminated ones for sale, but they don't show a big enough picture to see if they are the same as the lame AIM and I don't need to get more of the same.
post #6 of 16 (permalink) Old May 11th, 11, 04:07 PM Thread Starter
Harvard
Where does your brown wire we discussed go into the bulkhead? Is it DU as listed above? And does yours have that orange wire to the terminal behind the battery and the one off the horn relay? If not I think I'm done. The white wire to the alt can wait.
post #7 of 16 (permalink) Old May 11th, 11, 05:10 PM
cb
I really don't know what the DU and other letters you use are... Are they one the fuse block itself? I just drew a figure of the shape of the fuse block and added numbers where there were wires... Basically using the figures from the AIM schematics (BTW, I really use the separate Wiring Diagram Manual that can be bought).
According to my drawing, the Brown wire is in the second slot in from the left, bottom row, on the right half of the block (light harness). It has VR Red on the left (Black in AIM) and Right Turn Signal Dark Blue on it's right. Basically, where the AIM shows it. But the figure is rotated 90 degrees clockwise in the AIM from how hit mounts on the firewall, right.
I will guess that only one wire goes to the Junction Block if the car has Waring Lights. The second wire, Black with Orange fusable link, used in my harnesses, goes to the Ammeter. The other wire from the Ammeter ends up at the Main Splice (Main Splice connects to Junction Block, VR, HR, and Alt.). The one to the Main Splice is Black with White and then has an Orange fusable link. If your GEN Warning light gets it's signal from the Ignition Switch, I would say the B/W is not needed, either...
Also, from all the pictures of the VR that I have noticed and saved (only about 5), the wire is Brown, not Pink. In addition, I've seen other people's version of schematics that have been changed by the creater to Brown... They also have a straight White wire to the Alt. Even the Console Gauges and RS Schematics document has that for the 69...
Do you want my diagrams that I made? Yes, they are for a car with gauges (and a couple other options). But maybe you can work backwards from there???
post #8 of 16 (permalink) Old May 11th, 11, 06:58 PM Thread Starter
Harvard
Thanks, I think I've got it. I have lots of wiring diagrams, but the biggest problem was the mix of gauges and lights in all of them and in the post on CRG I mentioned the 69 had brown like we have on ours.
My other problem is not knowing whether a PO had changed the harness or hacked it up etc. Having added the console gauges, I don't know what else they may have changed, but it seems it is the right harness and wires.
I added both the black and black with white striped wires to my car with the conversion harness, so it didn't have them before that at all.
I think I can go with your description of where the brown wire goes in the harness without seeing a pic. If you look on most of the wiring diagrams they have letters beside the wire positions and that's where I got the DU (they are on the bulkhead connectors too). Once I get the harness out and the dash undone it will be more clear to me how things go. I just wanted to be ready when I got there and not sit with it like that while I waited for an answer to something I couldn't figure out. Many thanks.
post #9 of 16 (permalink) Old May 11th, 11, 07:01 PM Thread Starter
Harvard
Now I need to find a source for some of the connectors and the wire.
post #10 of 16 (permalink) Old May 11th, 11, 07:07 PM
Daryl
1968RallySport's Avatar
American Autowire will sell some of the connectors.
1968RallySport is offline
post #11 of 16 (permalink) Old May 11th, 11, 07:10 PM
1. Yes, white turns to orange between alt & VR. Orange is fusible link.White wire to left terminal on alt, orange on VR #2.
Blue wire from VR F to right terminal of alt connector. VR #3 is red from a factory crimp to red wire from junction block to horn relay, could attach to horn relay buss bar.
2. Pink from VR #4 to firewall connector, then brown inside interior. Then brown to inst cluster.
3. Not needed for idiot light dash, only used for OE ammeter.
post #12 of 16 (permalink) Old May 12th, 11, 03:12 PM Thread Starter
Harvard
I e-mailed them and they said no.
post #13 of 16 (permalink) Old May 12th, 11, 03:21 PM Thread Starter
Harvard
Are you going from a car or the Wiring diagram?
post #14 of 16 (permalink) Old May 12th, 11, 03:22 PM
Diagram and what I remember from previous owned Camaros.
Also, Motors Manual, 1974.
However, it may not be gospel by color, but, wire routing is correct.
post #15 of 16 (permalink) Old May 12th, 11, 03:55 PM Thread Starter
Harvard
Thanks.
