69 console gauge wiring - Team Camaro Tech
post #1 of 13 (permalink) Old May 9th, 11, 08:09 PM Thread Starter
Can someone tell me where this yellow wire goes. It is from a repo console gauge harness for a 69 4 speed car. Also, how about this orange one from under the dash near the ash tray area. Thanks
[IMG]httphttp://i1096.photobucket.com/albums/g339/ragtop68rs/pacecarpics008.jpg://i1096.photobucket.com/albums/g339/ragtop68rs/pacecarpics009.jpg[IMG]
Sorry about the pics, I'll try it again.
68 RS convertible with a 2002 LS1/4L60E
john68conv is offline
post #2 of 13 (permalink) Old May 9th, 11, 08:59 PM
Re: 69 console gauge wiring
Guessing w/o seeing a picture....
Orange is probably the cig lighter wire - does it have a round platic connector on the end?
Yellow likely is the "low fuel" warning wire.
BPOS is offline
post #3 of 13 (permalink) Old May 9th, 11, 09:05 PM
Jeremie
x2
I just taped up the yellow wire, I think it had a brown connector on it? I did not have the low fuel warning light
MTN10 is offline
post #4 of 13 (permalink) Old May 9th, 11, 09:06 PM
The orange wire is probably something in the courtesy lighting circuit, ash tray, glove box, console lighting. The yellow wires I think were used for a radio wire and the low fuel light circuit.
Ron
The “
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #5 of 13 (permalink) Old May 9th, 11, 09:33 PM
69-Pace's Avatar
The orange is the dome light at the rear of the console.
The yellow is the low fuel cell.
Here is a link to the console gauge diagram in pdf. I know there is a better quality one out there but can't find the link but this one will do.
http://www.rclabbe.com/rswiring/rswiring.pdf
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 13 (permalink) Old May 10th, 11, 03:18 PM Thread Starter
Thanks guys, the yellow makes sense for the low fuel. The orange is not the lighter wire with the round end. It has a strange looking end kind of like the yellow low fuel wire.
post #7 of 13 (permalink) Old May 10th, 11, 04:20 PM
The orange could also be the glove box light wire. Flat plastic end, white?
BPOS is offline
post #8 of 13 (permalink) Old May 10th, 11, 06:54 PM Thread Starter
I will try the pics again.
Name:	pace car pics 009.jpg
ID:	22309   Click image for larger version
Name:	pace car pics 008.jpg
post #9 of 13 (permalink) Old May 10th, 11, 09:56 PM
According to my diagram, most of the orange underdash wires are all on the same circuit - cig lighter, GB light, under dash courtesy lights, dome light (not on a conv though), rear console light, and a clock power wire. These should all be hot with the key off. You might put a test light on it.
There should also be an orange going to the brake light switch from the fuse panel, and one from the headlight switch to the fuse panel.
BPOS is offline
post #10 of 13 (permalink) Old May 11th, 11, 12:07 AM
Jon
I have an orange wire that looks just like that under my dash as well. That wire and another orange wire have been taped off ever since I have owned it. I would like to know what they are for.
jonny69'302 is offline
post #11 of 13 (permalink) Old May 11th, 11, 05:35 PM
cb
Send a message via Yahoo to flyingskibiker
The Orange wire is for the glove box light. You can see it hidden behind the coil of wires in the picture below of the part.
http://shop.americanautowire.com/55-...tassembly.aspx
The Yellow is for the Low Fuel Warning Module.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #12 of 13 (permalink) Old May 11th, 11, 07:05 PM Thread Starter
Thanks guys, that helps a lot.
post #13 of 13 (permalink) Old May 11th, 11, 08:12 PM
I'm pretty sure they all have the orange wire for the glove box light. If the car didn't come with the light, the wire was left taped up in the harness with a clear plastic cover. That wire is a constant hot wire.
Ron
The “
Geezer is offline
