Alternator choice - Team Camaro Tech
post #1 of 8 (permalink) Old May 10th, 11, 09:24 AM Thread Starter
Alternator choice
Is there any reason not to upgrade a 10si to a 12si alternator? I'm not working on a numbers matching car.
sthoma10 is offline
post #2 of 8 (permalink) Old May 10th, 11, 02:00 PM
Re: Alternator choice
I don't care for the plastic fan, but otherwise, not an issue as long as your wiring can handle whatever current capacity you choose.
go2fast is offline
post #3 of 8 (permalink) Old May 10th, 11, 05:09 PM
Larry
larryh56's Avatar
Nope! There a few good reasons to make the upgrade like better cooling and higher output in stock form. Check out this article: http://www.madelectrical.com/electri...elcoremy.shtml
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #4 of 8 (permalink) Old May 10th, 11, 07:14 PM Thread Starter
Thanks for the suggestions. The wiring is stock so how much would you guess it can handle? I was thinking around a 100 amps.
sthoma10 is offline
post #5 of 8 (permalink) Old May 10th, 11, 08:18 PM
Steiner
110A one wire 10SI form DB Electrical here, chrome for $61. Stock wiring is only 10AWG so it can support 30A max continuous but your fusible link protects it. Alternators are demand driven....they'll only put out as much current as you require while maintaining voltage level. I personally have an auto reset circuit breaker in place of the fusible link. Then I've got another 80A fused cable feeding a couple small fuse blocks that any non-original device is supplied from (OK, the HEI and EFI ECM still come off the stock fuse block).
Anyway, with an HEI, high pressure EFI pump, a few other devices, etc. etc. I get 14.4V steady at idle. Those models put out 65A at 600 RPM and full current at 1200 RPM and they put the big fan on them.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 8 (permalink) Old May 11th, 11, 07:06 AM
Michael
The big fan is for big cooling. I run the 12-SI and it's been the most dependable alternator I've ever installed.
I tried the CS alternators (even the w/Iceberg), but haven't had much luck. I tried 3 and all 3 failed. If your battery goes down or there's a voltage spike they seem to take it bad and fail. They seem to be fragile and failure prone.
The 12-SI could care less and just keeps chugging along producing lots of power reliably.
You should upgrade your wiring to the horn relay and take fusible link precautions like Steiner says.
mahunt is offline
post #7 of 8 (permalink) Old May 11th, 11, 01:57 PM
I went with a CS130 (105 Amp) which needed a few wiring tweaks.
It's for a 89 Pontiac Safari station wagon...stock looking fan and V-pulley.
68 Camaro~LSx ~all motor
post #8 of 8 (permalink) Old May 12th, 11, 12:53 PM
Greg
I got my 12si from Autozone. 78amps is enough and I have an electric fan and water pump. About $50 with a lifetime warranty. I'd also recommend a 3 wire setup over a 1 wire deal, especially if you have an electric fan.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
