Neutral saftey switch for console - Team Camaro Tech
post #1 of 9 (permalink) Old May 11th, 11, 01:56 PM Thread Starter
Jimmy
I ordered a neutral saftey switch for my console shifter, it looks like I got the wrong one, it looks like it should be on the column.
Can you see any diffrence between them?
The old neutral saftey switch was located on the column, the car was original a inline 6 car.
Bosing is offline
post #2 of 9 (permalink) Old May 11th, 11, 03:32 PM
Re: Neutral saftey switch for consol
Yes, they are different. A column mounted switch has right angle brackets to bolt the switch to the top of the column.
The console shifter mounted switch has flat mounting brackets.
You might be able to exchange it for a console switch.
post #3 of 9 (permalink) Old May 11th, 11, 03:44 PM
Here's one from my 69. You can kinda see what it should look like.
BPOS is offline
post #4 of 9 (permalink) Old May 11th, 11, 03:55 PM
I'm corrected, Thanks Al, for the picture.
post #5 of 9 (permalink) Old May 11th, 11, 11:58 PM Thread Starter
Jimmy
Thanks, the fun part is that I recived the wrong Neutral saftey switch twice.
Bosing is offline
post #6 of 9 (permalink) Old May 12th, 11, 09:55 AM
Re: Neutral saftey switch for console
Picture of your incorrect switch and the present switch you have now?
post #7 of 9 (permalink) Old May 12th, 11, 12:04 PM Thread Starter
Jimmy
Found a neutral saftey switch for console in the garage, didnt mount it on my Chevelle 1970 last year.
When you have the correct parts its much easier it worked on the first try.
Bosing is offline
post #8 of 9 (permalink) Old May 12th, 11, 12:06 PM Thread Starter
Jimmy
This is for the console:
http://www.ecklerschevelle.com/asset...sku/631312.jpg
This is for the column:
http://www.ecklerschevelle.com/produ.../2620/image/0/
The column has different mounting.
Bosing is offline
post #9 of 9 (permalink) Old May 12th, 11, 12:06 PM
Cool!
