clock fix? - Team Camaro Tech
post #1 of 10 (permalink) Old May 12th, 11, 05:34 PM Thread Starter
clock fix?
Has anyone fixed a clock that is only right twice a day??
Has anyone seen a tach that fits in the clock space?? I really dont need the clock but hate looking at one that doesnt work,,,or a hole.
Or maybe a tach where the tach was in these cars and the gas gauge where clock goes???
OR was there a clock delete blank that fits there??
Orange 69 Camaro is offline
post #2 of 10 (permalink) Old May 12th, 11, 05:44 PM
Jeff
yellow69RS's Avatar
Re: clock fix?
I haven't seen a "clock delete" plate. Clocks are an option so technically they can't be deleted, they just are not ordered. I've only had one car with a clock, that one had a lens in front of the clock as a separate piece. The rest have a "plate" there that is part of the dash carrier. I've never owned a 69 with a tach but I think there might be a center gas gage available for cars with tach and no console and console gages
Jeff
yellow69RS is offline
post #3 of 10 (permalink) Old May 12th, 11, 06:42 PM
Re: clock fix?
I had a small tach that fit in the clock space many years ago. It was a stewart warner and was the same size as a regular guage but that was back in the mid 80s.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #4 of 10 (permalink) Old May 12th, 11, 07:10 PM
69-Pace's Avatar
Re: clock fix?
You could try a aftermarket tach or just replace the dash pod. All the replacements I've seen at classic, ricks etc all come without the clock cutout. Or order a replacement or rebuilt clock available at the same places and flea-bait.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 10 (permalink) Old May 12th, 11, 07:20 PM
Mike Montgomery
Re: clock fix?
You could have your clock repaired. I had mine fixed but it only lasted two years. I then had a new quartz movement installed and now it keeps perfect time.
Reynolds Speedometer
2631 River Reach Drive
Naples, FL 34104-6932
(239) 643-4103
michael montgomery<BR>69 SS 396/350
michaelm5 is offline
post #6 of 10 (permalink) Old May 12th, 11, 08:20 PM
Alan
Re: clock fix?
Does someone sell the quartz retro fit as a kit or do you have to send your old clock in?
alan
alanrw is offline
post #7 of 10 (permalink) Old May 12th, 11, 08:39 PM
69-Pace's Avatar
Re: clock fix?
alan
Classic sells a quartz rebuild kit.
69-Pace is offline
post #8 of 10 (permalink) Old May 12th, 11, 09:15 PM
cb
Send a message via Yahoo to flyingskibiker
Re: clock fix?
I did the quartz replacement on my 68 years ago. Still works great. Easy to do, too.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #9 of 10 (permalink) Old May 12th, 11, 09:23 PM
Re: clock fix?
I put my clock in a baggie sprayed with wd-40 and let it sit overnite...been working for two years now! FWIW.
reelknots is offline
post #10 of 10 (permalink) Old May 13th, 11, 09:09 AM
click's Avatar
Re: clock fix?
Mine died too, rather than spend a fortune having it rebuilt I used a small hobby store clock battery operated type. It mounted right in the same center hole, I had to change the battery after 2 years but this worked for me all that is missing is the shaft that worked the clock hands from the front.
click is offline
