Wiring help- new alternator - Team Camaro Tech
post #1 of 24 (permalink) Old May 20th, 11, 12:51 PM Thread Starter
I have a 68 with a/c which in the past has been upgraded to a 10si 63 amps. Along wi the upgrade the wiring from the alternator to the battery was upgraded to 8 gauge. the alt is loosing a bearing so I'm going to upgrade to a 12 si 93 amps. My question is about wiring.
1. Should I upgrade to 4 gauge with an 80 amp fuse?
2. If I re-wire can I run a new line directly from the alt to the battery bypassing the horn relay and the passenger side junction box but keep the old 8 gauge line connected to the battery kind of letting the current backfill the horn relay? I was thinking that the relay and/or junction box would be weak links for the beefed up amps.
sthoma10 is offline
post #2 of 24 (permalink) Old May 20th, 11, 01:08 PM
Re: Wiring help- new alternator
Do you have a lot of accessories that draw a lot of current?
The diagram I have seen that makes the most sense is to run an 8ga wire (witha 12ga fusible link) from the stud on the alt to the horn relay for remote sensing, and connect the original 10ga sense wire that originally went between the alt and the horn relay to the junction block ahead of the battery, giving you two 10ga wires between those two. http://www.hotrod.com/techarticles/m.../photo_22.html
BPOS is offline
post #3 of 24 (permalink) Old May 20th, 11, 05:34 PM
Steiner
That's what I did (one wire alt).... Heaviest premade cable the parts store had from alt to battery, then an auto reset circuit breaker between the battery and horn relay instead of fusible link. Left the original cable to the horn relay since I put in a fused auxiliary feed coming off the battery for new stuff.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 24 (permalink) Old May 20th, 11, 10:50 PM
Larry
larryh56's Avatar
Check out this article: http://www.madelectrical.com/electri...evymain1.shtml
Using your horn relay as the main power distribution point as Al said is a good way to go.
PS I have read you can't buy stuff from MAD Electrical any more.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 24 (permalink) Old May 21st, 11, 06:16 AM
I don't understand why these diagrams include a fusible link in the alternator wire. The alternator is incapable of putting out enough current to fuse the wire.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #6 of 24 (permalink) Old May 21st, 11, 06:49 AM
prostreet69camaro's Avatar
Mad Electrical has some articles on there website. You want the alternator to sense the load. The alternator will control itself to charge the battery as needed.
If you have circuits running from the battery to like fans, fuel pumps, etc, the alternator will not sense the load. So it will not adjust the voltage to charge the battery as the battery is depleted.
prostreet69camaro is offline
post #7 of 24 (permalink) Old May 21st, 11, 06:52 AM
The mad electrical doesnt show a fusible link on the alternator wire. It shows a #14 from the battery to the horn realy and #16 to the main power wire going inside the car.
post #8 of 24 (permalink) Old May 21st, 11, 03:00 PM Thread Starter
Thanks for the comments and suggestions. I wonder why Mad electric suggests 8 gauge to the horn relay but nothing further? Is the main draw only to this point and not the battery?
sthoma10 is offline
post #9 of 24 (permalink) Old May 21st, 11, 04:25 PM Thread Starter
But mad electric includes a 12 gauge fusible link in their alternator wiring kit for high amp upgrades!
sthoma10 is offline
post #10 of 24 (permalink) Old May 21st, 11, 10:59 PM
Larry
larryh56's Avatar
This is to ensure that max power is being delivered to the horn relay and this is where they recommend you draw power for the accessories. There is a fusible link for the wire attaching to the batt terminal on the alternator. That wire is always hot and if it shorted the fusible link will burn as all the power for the car goes through that wire except when the car is starting.
Samuel Adams
larryh56 is offline
post #11 of 24 (permalink) Old May 22nd, 11, 05:59 AM
I was referring to the above linked drawing - http://www.hotrod.com/techarticles/m.../photo_22.html
Why would they do this?
post #12 of 24 (permalink) Old May 23rd, 11, 05:42 AM
Greg
The diagram above is what I did. To the OP, what electrical accessories do you run? I have electric fan, fuel pump, water/meth pump and the 12si 78 amp alternator works plenty fine for me. My fan is not a real high draw one though. Some fans alone can draw 40 amps.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
post #13 of 24 (permalink) Old May 23rd, 11, 06:50 AM Thread Starter
Thanks. All I have now now is an A/C car with HEI but with the alternator going I had wanted to have in place a charging system that could handle any upcoming additions like fans.
sthoma10 is offline
post #14 of 24 (permalink) Old May 23rd, 11, 08:29 AM
Good question. The factory used a fusible link from the junction block to the battery+, and that is not shown in the diagram.
BPOS is offline
post #15 of 24 (permalink) Old May 23rd, 11, 09:43 AM
Greg
1- no need to upgrade to 4 AWG. 8 should be more than plenty
2- Do not do this, they are not weak links. Also, when you add fans later on, etc. wire them with a relay and have the main power feed come from the horn relay buss bar for optimal performance.
With just AC and HEI, a 78 amp would still give you room to grow with an electric fan IMO.
Greg O is offline
