Ground on Positive side - Team Camaro Tech
post #1 of 3 (permalink) Old May 29th, 11, 02:40 AM Thread Starter
Car started fine a few months ago after replacing the engine, sat for a few months and went to start it to move for resurfacing the garage floor with Expoxy Coating - no start! Did some probing and to make a long story short, my test light showed I had positive voltage to the engine block! Started disconnecting things and found that when I disconected the wire from the battery to the fusible link the positive to the block went away - so I assume I have a short to ground on that side of the harness somewhere. Wierd thing is when I put both gournd and positive cable on the battery I get no arc - with a positive ground to the body / engine I would expect a huge arc hooking up the battery, and yes the battery has a good charge - started my other Camaro fine. Thoughts?
69 Pace Car and 69 Hard top
srode is offline
post #2 of 3 (permalink) Old May 29th, 11, 05:40 AM
Re: Ground on Positive side
A dirty ground connection.
But as I read in your case, you probably have the test light on the clamp bolt and have a light when touching block. Touch the cable terminal on the block /connection point and if no light, it's the surface contact between the terminal and connecting piece.
post #3 of 3 (permalink) Old May 29th, 11, 01:59 PM Thread Starter
Nailed it Everett - good trouble shooting.
Thanks! Steve
srode is offline
