Moved Battery to Trunk - Team Camaro Tech
post #1 of 14 (permalink) Old May 29th, 11, 11:52 AM Thread Starter
Did a very basic battery-to-trunk project. Built the bracket out of an old hollywood bed frame, and ran 1/0 welding cable for the pos wire over the wheel well and into the wiring gutter under the sill plate, and through a bulkhead connector under the heater box, then a short cable to the solenoid. The neg cable is simply attached to the q-panel support (convert) where there is an unused 3/8-16 nut welded there. At the front, I used a 1/0 ground from the subframe (welded a nut there) to the engine block. I have welded SFC's on the car. While I was at it, I wired the purple "S" wire to a 50A Bosch relay, which draws power from the bulkhead connector. Also installed a PMGR starter. It all seems to work very well.
BPOS is offline
post #2 of 14 (permalink) Old May 29th, 11, 12:21 PM
Re: Moved Battery to Trunk
I'll also be running the battery in the trunk in my project '68, but with a remote solenoid as well. I just don't like the idea of a big, unfused, constantly hot 12 volt cable running the length of the car.
Probably overkill, but then that describes the entire project.
Trunk looks good with the new spatter paint and nice job on the bracket.
Mike - '68 Camaro - aftermarket or modern pretty much everything.
Mkelcy is offline
post #3 of 14 (permalink) Old May 29th, 11, 12:54 PM
Steiner
http://cgi.ebay.com/200-AMP-12-VOLT-...item19bdcc02df
http://cgi.ebay.com/200-amp-MANUAL-R...item231075eae8
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 14 (permalink) Old May 29th, 11, 01:15 PM
That's one solution. I still prefer a dead 200 amp circuit unless I'm starting the car, to a constant hot, fused 200 amp circuit. Maybe it's just me.
Mkelcy is offline
post #5 of 14 (permalink) Old May 29th, 11, 02:05 PM
Thats what I did....Ford noid in the trunk next to battery.
68 Camaro~LSx ~all motor
post #6 of 14 (permalink) Old May 29th, 11, 02:06 PM Thread Starter
I did give both of those options (solenoid, breaker) a lot of thought, and for sure both would be ultimately safer than what I did. But I don't believe what I did is unsafe. The cable is secured approx every foot with insulated clamps. I doesn't/can't rub against anything, and is not strapped under the car where it is subject to road rash.
If the same amount of care/concern was routinely given to the pos cable in underhood battery installs (battery mounted solenoids or breakers) I would take pause, but I just haven't seen that.
Anyway - that's how I rationalized my way out of a bunch of extra wiring. I don't fear the long cable!
BPOS is offline
post #7 of 14 (permalink) Old May 29th, 11, 02:15 PM
I'm not saying what you did was unsafe - I am saying I'm paranoid.
Mkelcy is offline
post #8 of 14 (permalink) Old May 29th, 11, 02:28 PM Thread Starter
We all need to be paranoid about something, Mike. I'm afraid of those goofballs in OT.
BPOS is offline
post #9 of 14 (permalink) Old May 29th, 11, 06:01 PM
Jon
Nice work!
Jon
My 72 Chevy Vega
My Garage Journal Build Thread:
jon72vega is offline
post #10 of 14 (permalink) Old May 30th, 11, 07:53 AM
Mickey
Moonpie's Avatar
Looks good, man.
What did you use for trunk finish? It looks good too.
Moonpie is offline
post #11 of 14 (permalink) Old May 30th, 11, 08:03 AM
prostreet69camaro's Avatar
Turned out nice. I did the same thing. Ford solenoid in trunk. I did hook my negative to the frame thought but I have a full frame car.
prostreet69camaro is offline
post #12 of 14 (permalink) Old May 30th, 11, 08:07 AM
Ever wonder how many thousands of daily driver cars have a factory installed rear battery with a hot cable running the length of the car?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #13 of 14 (permalink) Old May 30th, 11, 10:04 AM Thread Starter
Originally Posted by Moonpie View Post
Looks good, man.
Thanks Moon. The trunk finish is Zolatone Onyx-Black over a coat of black epoxy primer.
BPOS is offline
post #14 of 14 (permalink) Old May 30th, 11, 10:10 AM Thread Starter
I factored that in as well. My brother has an '06 SS Cobalt and my dad has a 2000ish BMW, both with trunk mounted batteries and that's how they are done. Both also have a short neg cable grounded to sheetmetal.
BPOS is offline
