1967 camaro rs headlight relay board diagram - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 1st, 11, 04:20 PM Thread Starter
patrick
I am looking for a 1967 CAMARO RS HEADLIGHT RELAY BOARD DIAGRAM to be more specific what wire connectets to the circuit breaker on the reay board?
shox987 is offline
post #2 of 8 (permalink) Old Jun 1st, 11, 05:18 PM
Re: 1967 camaro rs headlight relay board diagram
A large gauge red wire is the feed to it. A smaller gauge orange wire goes on the other post.
Here's a photo. My wires to relays are not in factory locations but that doesn't matter(to me) as long as they are sorted correctly.
Melrose RS is offline
post #3 of 8 (permalink) Old Jun 1st, 11, 06:50 PM Thread Starter
patrick
thanks
shox987 is offline
post #4 of 8 (permalink) Old Jun 1st, 11, 07:12 PM
Roger
rogerh's Avatar
Pat
Hope this will help.
Roger
ID:	22661   Click image for larger version
ID:	22662   Click image for larger version
rogerh is offline
post #5 of 8 (permalink) Old Jun 1st, 11, 07:38 PM
If originality isn't a concern you can do away with the relays and limit switches etc. and wire in a headlight control module from a 92-02 Firebird. Pretty slick deal.
BPOS is offline
post #6 of 8 (permalink) Old Nov 25th, 15, 04:35 PM
Chris
130fe's Avatar
Thumbs up Re: 1967 camaro rs headlight relay board diagram
Al, do you happen to have any links to that conversion? Thanks!
Never mind, found it Thanks!
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #7 of 8 (permalink) Old Nov 25th, 15, 05:16 PM
Chris
130fe's Avatar
Al, what is the difference between the wiring diagrams with and without the bosch relay?
Chris
130fe is offline
post #8 of 8 (permalink) Old Nov 25th, 15, 09:44 PM
Rick
And for some more info. https://www.facebook.com/media/set/?...4909802&type=3
Last edited by Ric67; Nov 25th, 15 at 09:45 PM. Reason: link did not load properly
Ric67 is offline
