Wiper adjustment - Team Camaro Tech
post #1 of 17 (permalink) Old Jun 12th, 11, 11:56 AM Thread Starter
kevin
Wiper adjustment
I am trying to hook up wipers on my 68. Motor is in, wired, ( appears to be never reasd any operating fine) have what seems to be the correct arm yet when attatched to the wiper transmission it runs 1/2 and seems to jam. I cannot see it binding anywhere. When trans disconnected from armm everything seems to move freely. It is almost like the arm is the wrong lenght. I check against pictures here and everytghing seems ok. Do I need to put a little bend in the linkage or am I missing something. I've searched, seen others with a similar problem but never read of a cure HELP!!!
harddock is offline
post #2 of 17 (permalink) Old Jun 12th, 11, 01:00 PM
Steps
Re: Wiper adjustment
I had an issue just like that last time I got the car painted....only time I have had the car painted rather than do myself
Afdter a lot of measuring, cant find anything, turnd out someone had climbed up on the car ro sand the roof or something, put their weight on the area under the cowl and the 'plate parts had been 'pressed down slightly....
A bit of tweeking with the crow bar and blocks of wood fixed the issue.
Steptoe is offline
post #3 of 17 (permalink) Old Jun 12th, 11, 01:57 PM Thread Starter
kevin
I got to the point where I had to walk away. I can't find what is binding. I can see around everything. I'll go back to it tommorrow and see what's what. It acts as if the linkage is too long and won't swing past the 2 o clock mark on the motor.
harddock is offline
post #4 of 17 (permalink) Old Jun 12th, 11, 11:15 PM
cb
Send a message via Yahoo to flyingskibiker
To check if the arm is too long, have you tried moved the trasmission in a simulated circle the arm travels with the trasmission off the arm?
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #5 of 17 (permalink) Old Jun 12th, 11, 11:24 PM
Gary
also, check to make sure the screws that hold down the cowl panel are not too long otherwise they will interfere.....ask me how I know
Gary
Gar's67 is offline
post #6 of 17 (permalink) Old Jun 13th, 11, 04:18 AM Thread Starter
kevin
If I try to rotate as if it were on the arm I get the same effect (binding) If I chocke up on the throw I think they would rotate fine.
As for the cowl panel that's not an issue (yet) as the panel is not on
harddock is offline
post #7 of 17 (permalink) Old Jun 13th, 11, 05:01 AM
Tim
Does the arm linkage return to the correct "park" position after completing a cycle?
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #8 of 17 (permalink) Old Jun 13th, 11, 09:53 AM Thread Starter
kevin
wiper motor returns to the same 7 o clock (looking at the nut inside the cowl) when switch is turned off.
harddock is offline
post #9 of 17 (permalink) Old Jun 13th, 11, 10:47 AM
I had a similar issue once. In my case it was caused by someone snapping and re-drilling the wiper mounts a little off. Apparently it doesn't take much.
go2fast is offline
post #10 of 17 (permalink) Old Jun 13th, 11, 11:00 AM Thread Starter
kevin
It almost seems like the wiper motor offset shaft is too far towards the passenger side. I have a lot of throw area to the drivers side but not the passengers. Can the motor be turned in the housing?
harddock is offline
post #11 of 17 (permalink) Old Jun 13th, 11, 02:52 PM
Steps
Correct which was my issue in a different area
Are these the orginal arms that have worked in the past....Im assuming yes up to this point.
Steptoe is offline
post #12 of 17 (permalink) Old Jun 13th, 11, 04:43 PM Thread Starter
kevin
I don't know. The transmission was there. The wiper motor and arm are new from Ricks. I never got a wiper motor with the car.
They(Ricks) only make one wiper motor for a 68, the transmission linkage may or not be original.
It appears that if the ball on the arm was where the shaft itself is it would work properly.
harddock is offline
post #13 of 17 (permalink) Old Jun 13th, 11, 07:51 PM
cb
The arm on my spare motor measures about 1 15/16" from the nut to the ball. The arm is about 1" from the body to the face where the ball mounts (ball side). My arm stops closer to the 8 o'clock position as shown in the AIM. It's almost at it's furthest to the driver's side as it gets, relative to the trans. arm/rod.
Do you have a gasket between the wiper motor and firewall? Maybe that is enough to make a difference (if missing).?.?
You might also do a couple firm pulls against the binding to see if you can hear where it is? I'm thinking out loud here...
post #14 of 17 (permalink) Old Jun 14th, 11, 03:24 AM Thread Starter
kevin
Does anyone have the measurement differences between 67&68 linkages. The motor, arm and mounting all seem to be correct. The linkage can't go in backwards can it? One rod from DS wiper to PS wiper and one rod from PS wiper to motor.
harddock is offline
post #15 of 17 (permalink) Old Jun 14th, 11, 12:50 PM Thread Starter
kevin
Update. Knowing I had the right motor, arm, & transmission I started from scratch by removing the transmission. Started on the passsenger side and found one bolt was about 1" long and the other about 1/2". I remounted the passenger side with just the 1/2" bolt and tested the fit. Well don't you know it worked. The 1"bolt was bent and I cut a good 1/4" off and reused it. Cowl is on, wipers are on and we're good to go!! \Thanks for all the suggestions and guidance.
harddock is offline
