67 delux wheel / horn - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 14th, 11, 09:10 AM Thread Starter
Bruce
Hi! I've got my 67 delux wheel on the tilt colum but having a problem with the horn ... My parts are orig, best I know. My problem is the horn will not shut off. My questions #1 - If you look at the metal plunger as a nail, best I can tell from pictures, the head goes against the spring leaving the shaft sticking up? 2 - Does the spring plate have plastic around the edge as in this photo?
http://www.ss396.com/mm5/merchant.mv...=STEERINGWHEEL and last #3 My small plastic spacer has a "pin" coming out the side which seems to **** it to one side ... Do I need to remove that? Thanks!!!!
RAGMARO is offline
post #2 of 2 (permalink) Old Jun 14th, 11, 10:56 AM
Vintage 68's Avatar
Wink Re: 67 delux wheel / horn
"Search" is always your best friend
https://www.camaros.net/forums/showthread.php?p=979985
1968 Convertible
Some trucks
Vintage 68 is offline
