Battery Drain on new build - Team Camaro Tech
post #1 of 17 (permalink) Old Jun 15th, 11, 02:50 PM Thread Starter
Clint
Any advice on how to start troubleshooting a battery drain problem? I have a newer frame off resto, 350 crate and AAW classic update wiring harness. I finally had the courage to leave my battery hooked up for a week and now it's dead. Not sure where to start?
Clint
cwb90 is offline
post #2 of 17 (permalink) Old Jun 15th, 11, 04:24 PM
69-Pace's Avatar
Re: Battery Drain on new build
Check the obvious things like an always on trunk light, glove box light, or hot wired radio. If not there then check electrical subsystems one by one.
Let us know the year and style of your ride along with options installed factory and aftermarket that will help. Is the Voltage Regulator new or original? Original or conversion alternator, stock distributor and ignition system?
Have you tested how much current is being drawn from the battery yet? I assume there is some original harnesses left when using the classic update or does it replace everything - only adding new style fuse system?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 17 (permalink) Old Jun 15th, 11, 05:28 PM
cb
Send a message via Yahoo to flyingskibiker
A quick test is to pull the fuses one at a time until the drain goes away. Though, not everything is fused... But other things can be disconnected, as well. Like the alt., VR, HR, etc.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #4 of 17 (permalink) Old Jun 15th, 11, 06:08 PM
Rig up a test light between the battery cable and battery post and look at the bulb glow.
As suggested, disconnect all electric devices one at a time and the one reducing the glow is the problem circuit.
post #5 of 17 (permalink) Old Jun 16th, 11, 02:20 PM Thread Starter
Clint
Just so I understand this.........if I have a short the test light bulb will glow when placed between the battery post and cable, correct? Do I check this on the positive or negative or doesn't it matter?
Thanks everyone for the help. I will try this over the weekend and get back with everybody.
Clint
cwb90 is offline
post #6 of 17 (permalink) Old Jun 16th, 11, 04:53 PM
DT
Donny
DT's Avatar
positive terminal to positive cable. If you have a short, it will light up (dim light usually)
DT is offline
post #7 of 17 (permalink) Old Jun 27th, 11, 12:14 PM Thread Starter
Clint
Thanks everyone for the help. Here is where I'm at..........I tried the test light between the cables and the light will glow for about 2-3 seconds and then go out. I removed the fuses and any other wires one at a time and still had the test light glow. I also removed my electric fan wire and the alternator battery wire and still had the problem. I also get a arc while connecting my negative cable up.
I have the AAW classic update kit with electric fan, Vintage air, Mallory SS Comp distributor and coil if that helps anyone.
Clint
cwb90 is offline
post #8 of 17 (permalink) Old Jun 27th, 11, 01:51 PM
Jeremie
Make sure the door is closed when you perform this test.
69 327/332hp Le Mans Blue
71 C-10
MTN10 is offline
post #9 of 17 (permalink) Old Jun 27th, 11, 02:23 PM Thread Starter
Clint
I did it with the door open. What problem would this cause?
Clint
cwb90 is offline
post #10 of 17 (permalink) Old Jun 27th, 11, 04:12 PM
Door open, dome lights on, do the test on neg cable, always disconnet neg first, connect last.
john68 is offline
post #11 of 17 (permalink) Old Jun 27th, 11, 05:43 PM
Clint
If test light is on for about 2-3 seconds, do you have an OE electric clock?
An aftermarket stereo/amp?
Unplug voltage regulator?
post #12 of 17 (permalink) Old Jun 28th, 11, 01:50 PM Thread Starter
Clint
Tried this and still had the same results.
No OE clock. Have retrosound radio with no amp, pulled hot lead for radio during testing. Voltage regulator is internal to alternator and unhooked the battery leads to it and still had a glow on the test light.
Thanks to everyone so far for the help. Please keep the ideas coming if you could think of anything.
Clint
cwb90 is offline
post #13 of 17 (permalink) Old Jun 28th, 11, 04:25 PM
Banned
Bethanne
Nashville Beth's Avatar
Watch this; it shows how to detect very small current drains :
http://www.youtube.com/user/scottyki.../0/B__DqK90IIc
Nashville Beth is offline
post #14 of 17 (permalink) Old Jun 28th, 11, 07:17 PM
Keep the light hooked up and unplug every device one at a time and check glow.
When everything is unplugged, disconnect the red wire going into the firewall and check.
If it is still glowing, check/remove the positive pigtail junction block from the rad support next to the battery. Sometimes there is rust build-up between the stud and support - high resistance - very low current drawn.
If bulb goes out, then a dash harness problem. Red wire inside feeds two devices - ign sw & head light switch and fuse panel for convenience circuits - courtesy lights, glove box light, trunk light, cig lighter, any device you can think, disconnect it.
Once the light is out from the last circuit, reconnect the last circuit, disconnect both battery cables and measure the resistance across both cables - it will be a high resistance, >100K ohms meaning microamps of current drawn, a low glow.
Good luck, may the force be with you...........
post #15 of 17 (permalink) Old Jun 28th, 11, 11:10 PM Thread Starter
Clint
Everret, thanks for the reply. Where do I disconnect the red wire from?
cwb90 is offline
