67 rs hideaway door troubles (i've tried everything) - Page 2 - Team Camaro Tech
post #16 of 17 (permalink) Old Jul 16th, 11, 07:15 PM
Re: 67 rs hideaway door troubles (i've tried everything)
Originally Posted by BrocVon67 View Post
Ok, I mixed up the facts on the high beam dimmer switch...I only have the normal beams. I just now tried switching on the high beams and I lost the headlights, BUT my interior lights stayed on...wth?
Losing high beams on the dimmer is typical of a bad dimmer switch. Try a new dimmer switch first. Interior lights stay on when they pick up a ground from somewhere they are not supposed to, like when one of your underdash light sockets pops out of its holder.
Melrose RS is offline
post #17 of 17 (permalink) Old Jul 16th, 11, 10:26 PM Thread Starter
Broc
I am fairly sure that I was using a newer dimmer switch...I'll try it in my brother's '68 and see what it does to his high beams. If it does the same thing to his, then I'll know for sure its the switch and I'll for sure replace it.
Thanks for the info!
Think that a bad dimmer switch would fail the rs doors from opening though?? ...even when I have only the normal beams turned on?
BrocVon67 is offline
Tags
67 rs, headlight doors, hideaway doors, troubleshoot, wiring
