Dash and Console Lights - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 17th, 11, 06:18 AM Thread Starter
George
Papa's Avatar
Hi All
Im having some trouble with Dash and console lights not working... the gauges and indicators are all fine i have checked the globes and i have used a test light to check but i still have no luck... I checked all fuses and they are all good except one its half the size of the others and its on the very bottom and im still waiiting for the manules to arrive..
must be a power issiue or could it be the switch
thanks
Papa is offline
post #2 of 6 (permalink) Old Jul 17th, 11, 06:24 AM
Jeff
yellow69RS's Avatar
Re: Dash and Console Lights
that little half size fuse is only live when the lights are on. It is the dash light fuse. If you have power on one side with the lights on you have found your problem.
Jeff
yellow69RS is offline
post #3 of 6 (permalink) Old Jul 17th, 11, 06:34 AM Thread Starter
George
Papa's Avatar
Dam i knew something was up with that fuse, I will check it in the next couple of days and get back to you
thanks Mate
Papa is offline
post #4 of 6 (permalink) Old Jul 18th, 11, 03:19 AM Thread Starter
George
Papa's Avatar
thanks Mate
jeff
came home this afternoon and first thing i did was check that fuse with headlight switch on and still nothing.. next thing i want to do is remove the switch and check it but need t oknow how that knob comes off i can see how to remove the rest of it but the knonb....
any other ideas please let me know
Papa is offline
post #5 of 6 (permalink) Old Jul 18th, 11, 03:26 AM
69-Pace's Avatar
the light switch assembly on a 69 has a small button on the bottom of the physical switch you have to push in in order to "unlock" the stem and be able to pull it out of the assembly. Need small fingers.
But I would just see if the light switch has been rotated all the way to the dash light off position?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Jul 18th, 11, 03:30 AM Thread Starter
George
Papa's Avatar
ahh thanks brain
thought that would be the case but was looking on the stem.. from what you say its under button.
will give it a go tommorow.. the dash lights are really giving me hard time everything looks ok
Papa is offline
