Help with 67 RS Wiring - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 1st, 11, 08:48 AM Thread Starter
Question Help with 67 RS Wiring
Hey guys...
I was out in the garage installing the brand new front wiring harness and it was pretty much plug and play as I have the AIM with diagrams. I was doing OK until I got to the relay board and I got lost as to what color wires hooked to the three relays. The relays have two different connectors to each relay. One connector has three wires and the other connector has two wire, Based on the diagram attached I could figure out the correct relay for all all the three wire connector...but got lost on the two wire connector as I can't see them on the schematic.
http://www.pozziracing.com/Media/67rswire2.jpg
Also on the harness going to the limit switches on the radiator support I have a couple of wires that I can't ID.
On the left side near the headlight there is a long green wire that I can't figure out where it goes....all of the headlight, limit switch and RS motors are hooked up.
Also on the drivers side there is a green wire that exits the harness right at the same spot as the wire for the rad support limit switch, but there is only one connection (I think) on the switch. There is also a purple wire doing the same thing on the passenger side.
There is also a long grey wire on the passengers side by the headlight that I can't figure out. I know that it is not for the horns as I have them figured out.
Shame they don't have an actual stand alone schematic for this instead of having to work between the regular and RS one.
Any help identifying these rouge wire would help alot.
TIA
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #2 of 6 (permalink) Old Aug 1st, 11, 09:14 AM
Re: Help with 67 RS Wiring
Use the wonderful photos on this page for the wires on the relays.
http://retro-electro.net/FAQ67.html
Melrose RS is offline
post #3 of 6 (permalink) Old Aug 1st, 11, 09:28 AM Thread Starter
Tom!
Thanks with that even a cave man can do it!
Now on to the wires at the radiator support!
67 RS/SS Pictures
cpodeep is offline
post #4 of 6 (permalink) Old Aug 2nd, 11, 04:52 PM
Roger
rogerh's Avatar
Scott have you found your gound wires. There should be one on each end of the rad support. I believe the purple and blue wires are the park/turn lights. Check out the thread link below. I posted a few pic that may help.
Roger
https://www.camaros.net/forums/showth...adlight+Wiring
rogerh is online now
post #5 of 6 (permalink) Old Aug 3rd, 11, 12:46 PM
Armando
tejasrs/ss's Avatar
good info!! ~
Armando
1967 Chevy Camaro RS/SS
2012 Ford F150 Supercrew FX4
2007 Ford Mustang GT/CS (sold)
2002 F150 Harley Davidson (sold)
tejasrs/ss is offline
post #6 of 6 (permalink) Old Aug 4th, 11, 04:02 AM Thread Starter
Roger,
No the wires I'm talking about are not the parking/turn signal lights....they are a two wire connector and come off the harness at the right place. The grounds are hooked up one on the top part of the radiator support on the LH side and another on the RH side just above the battery junction block.
On the left side near the headlight there is a long green wire and there is also a long grey wire on the passengers side by the headlight...these wires are a single wire with a plug in connector.
I haven't had time to get back over to the car since posting this.....so maybe with the link that Tom provided....I can figure it out. If not....I will be like Arnold..."I'll be back"
67 RS/SS Pictures
cpodeep is offline
