Headlight upgrade - Team Camaro Tech
post #1 of 54 (permalink) Old Aug 14th, 11, 07:32 AM Thread Starter
Vic
cadmanof50s's Avatar
Send a message via Yahoo to cadmanof50s
Headlight upgrade
My '68 has a set of T3 headlamps.
Correct as they are, their light is yellowish and not that bright.
I would like to pull out the lamps, carefully store them away and put in updated headlights.
I know nothing about the different lamps and conversions that are available. I read through many posts..and I have decided I want to modify as little as possible.
All I want is something brighter. If possible I want to stay with a 7" sealed-beam that is a direct replacement for the T3. Do they make such a thing as a Halogen sealed beam?
Will my wiring and headlight switch take the current load from a halogen lamp?
I don't have to have fancy colored headlamps...just something brighter than I have today.
Thanks!
Vic
Vic Brincat
383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs
cadmanof50s is offline
post #2 of 54 (permalink) Old Aug 14th, 11, 08:25 AM
69-Pace's Avatar
Re: Headlight upgrade
There are a few decent H style conversion kits out there that use the existing setup and harness. A converter plugs into the standard plug and the sealed beam gets replaced with a plastic lens to house the halogen bulb. It is a quick conversion and works well. Here is a link to a conversion at Ricks http://www.rickscamaros.com/camaro-h...1967-1981.html
There are also those who put HID systems in which are NOT street legal since they can blind on-coming drivers because of the lack of a self leveling system. If someone would design that system HID could be legal, but until such time all those conversion kits being sold are not legal and should not be used.
Here are some other solutions using the existing T3 system intact. Many folks have installed power relays so power tap comes straight from battery side direct power, much brighter output since not using power from the alternator side. Here is a great how to from Mad Electrical:
http://www.madelectrical.com/electri...adlights.shtml
Others report that a simple change of the old style mechanical Voltage Regulator to a solid state external makes all the difference in the world for some.
I have a solid state VR myself, but I never had dull headlights with my mechanical one so I can't say myself if that was enough to boost output at the headlights.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 54 (permalink) Old Aug 14th, 11, 08:26 AM
The problems with dim headlamps:
1. External reg'd alts put out less voltage, especially with more electrical loads applpied.
You can check this voltage at the battery posts, or, at the headlamp socket.
2. Along with #1, the lamp power goes through the firewall twice, battery to h/lamp switch to dimmer sw to lamps. Dimmer switch might need replacing.
Measure voltage at the h/lamp socket and you might see 11+ volts.
A couple of fixes are install an internally reg'd alt and/or wire in a relay for each h/lamp using localized power, ie, pass side junction block for pass h/lamp, horn relay buss bar for drvr side h/lamp. And of course, ensuring a good ground is provided for all circuits to complete the circuit.
There are halogen lamps on the market as well as HID's, high intensity discharge lamps. There will require localized power due to the current drawn and h/lamp circuit becomes a control circuit instead of a function circuit.
Brain & I wrote at the same time. Yes, as Brian suggested, installing an electronic VR, Wells P/N VR715, does improve the performance of electrical system, plug & play.
post #4 of 54 (permalink) Old Aug 14th, 11, 10:07 AM Thread Starter
Vic
Thanks guys.
Everything is brand new or rebuilt. (Including wiring). So IMHO all components are functioning as they were intend to. I think the issues is I'm just used to driving newer vehicles which by their nature have better illumination systems.
I will look into using a Solid state external regulator.
If that doesn't work, I will investigate adding individual relays to head headlamp.
I definitely don't want to do an HID "conversion" especially if it implies anything legally questionable. But the one conversion from Rick's Camaros looks like the least amount of rewiring and work. (Will I still need to convert the existing wiring to handle higher current with this conversion...??)
Thanks again folks.
Let me try of out some of the suggestions.
Vic Brincat
post #5 of 54 (permalink) Old Aug 14th, 11, 10:29 AM
DjD
DjD's Avatar
I have Wagner Halogen sealed beam bulbs in my '69 that require no changes to your charging system and no mods to your car. Take the old lamp out and replace it with these...
They won't break the bank either.
http://www.summitracing.com/parts/WA...%7cYear%7c1969
...Dennis
DjD is offline
post #6 of 54 (permalink) Old Aug 15th, 11, 05:22 AM Thread Starter
Vic
Thanks Dennis,
After reading your post I went down to my local car parts jobber and asked for a set of halogen sealed-beams. Sure enough, they had a pair of 7" round made by Sylvania.
They were not quite as cheap as the ones you suggested but certainly reasonably priced. Installed them..and they worked great!! I ran the car with the lights on for a few hours to make sure that they weren't going to tax the electrical system and cause a fault. No problems.
The only thing I had to do (for what ever reason) is reset the aim a bit. Otherwise...they were a no-brainer swap and they illuminate much better than the old T3s.
Thanks Dennis and all.
Vic
Vic Brincat
post #7 of 54 (permalink) Old Aug 15th, 11, 06:06 AM
Vic...check for pm, eh?
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #8 of 54 (permalink) Old Aug 15th, 11, 08:15 AM Thread Starter
Vic
Capt, got your PM.
I did reply, but not sure if my replies are going through. So please email me privately at [email protected].
Vic
Vic Brincat
post #9 of 54 (permalink) Old Aug 15th, 11, 04:24 PM
Got your pm...and answered.
capt
I'm QUALIFYING!
post #10 of 54 (permalink) Old Aug 15th, 11, 06:15 PM
Kevin
SixtyAte's Avatar
I went with the Sylvania Silver Star Halogen headlights. No fancy hookups needed. Nice and bright white light. I got them from Advance Auto a while back for $26.00 each.
Kev
SixtyAte is offline
post #11 of 54 (permalink) Old Aug 15th, 11, 07:00 PM
Jerry R.
jr68's Avatar
Thanks Dennis ! I'm ordering mine tonite.
Had no idea they were that affordable. My lites are about as bright as candles.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #12 of 54 (permalink) Old Aug 16th, 11, 04:27 PM
jeff
I did the MAD electric relay conversion for my headlites and changed to the Sylvania Silver Star Lamps (H6024), night and day difference. I now have bright lites. One other thing to look into is the voltage regulator, I had pulsing from the old mechanical regulator and changed it out for a new electrioic one. Got it at Autozone around $14 (Wells VR715), I also put the old cover on the new regulator for a better look.
jkuro is offline
post #13 of 54 (permalink) Old Aug 17th, 11, 03:41 AM Thread Starter
Vic
I have purchased an electronic voltage regulator to replace my old mechanical. (Has not arrived yet).
But did not deploy relays for the headlights. I have been running with the new headlights for several days...no issues. I would think that if they were drawing too high of a current load, the circuit breaker on the headlight switch would have kicked in. There is a circuit breaker on the headlight switch, right?
Vic
Vic Brincat
post #14 of 54 (permalink) Old Aug 17th, 11, 06:46 AM
Vic,
Right
Everett
post #15 of 54 (permalink) Old Feb 25th, 12, 11:17 PM
Kevin
Is there any problem with using these new Halogen bulbs (6024) in our cars without the relays.. I have a new Factory Fit American Auto Wire harness and don't want to burn out anything. I heard the wiring can get hot.. And the lights could "flicker".
69Rook is offline
