68 engine harness onto a 67 - Page 2 - Team Camaro Tech
post #16 of 16 (permalink) Old Sep 13th, 11, 06:44 PM Thread Starter
Ryan
Re: 68 engine harness onto a 67
Originally Posted by oakster View Post
I wish I had a good one to send you. The plastic clips tend to break on the 67s when you take them off.
Can you use the one already on your car. I know that you'll be sol until you get a 67 harness if you use your clip and it doesn't work.
Best of luck
Ill have to check my car out when i get home from college on Friday and see what's there... You have some old ones that youre not using now? Despite the clips, If the connectors slide into each other as they should im sure i can come up with a way to get them to stay together...
Check out my build thread->>>
ryanangelo212 is offline
Tags
conversion, engine, harness, wiring
