Battery blew up in my '69 today! - Team Camaro Tech
post #1 of 17 (permalink) Old Aug 19th, 11, 05:44 PM Thread Starter
I have never had this happen before. I was sitting in the drive thru and shut off the car to place an order. As soon as I cranked it sounded like a shotgun went off under the hood. It blew the top half of the battery off! I ran in and got a cup of water and poured on the paint to wash off some of the acid then later after I got it home washed the entire area with baking powder mixture.
69 SS Silver Camro, LS3 efi, 4L60e with 2800 stall, mini tubed 12bolt 3.73, Ridetech front suspension ladder bar rear.
slugo10 is offline
post #2 of 17 (permalink) Old Aug 19th, 11, 05:59 PM
Re: Battery blew up in my '69 today!
Exact same happened to me two years ago, but while driving. My friend said "Sounded like that guy's car blew up" and as soon as my power steering went away as the motor died I sud "Uh, no, my car just blew up"
Turned out that the body shop that had just repaired front end damage mounted the voltage regulator in rubber well nuts w/o running a ground strap to the core supprt. Batt was charging @ 17+ volts.
BPOS is offline
post #3 of 17 (permalink) Old Aug 19th, 11, 06:55 PM
69-Pace's Avatar
Nasty situation when the cells blow like that.
Quality assurance is non existent these days on anything let alone a battery full of acid.
The benefit of the older style battery tops with plugs was that you could add distilled water to keep the cell full.
Now you can't on most and the name "sealed lead acid battery" is misleading since they continue vent off the acid/water vapor during charge leaving lead cells exposed which can cause hydrogen explosions.
Just count your blessings that the hood wasn't open at the time and that you, family, passersby didn't get sprayed with acid.
Paint can be repaired, eyes can't.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 17 (permalink) Old Aug 19th, 11, 07:10 PM
Yes, overvoltage charging can make for a messy situation.
post #5 of 17 (permalink) Old Aug 19th, 11, 07:32 PM Thread Starter
Ya makes me think for a second when connecting battery up now.
slugo10 is offline
post #6 of 17 (permalink) Old Aug 19th, 11, 07:35 PM
ZaCamaro69's Avatar
Good grief! Is this that common??
ZaCamaro69 is offline
post #7 of 17 (permalink) Old Aug 19th, 11, 07:48 PM
69-Pace's Avatar
It seems to be on the increase doesn't it. Back in the day I can only remember hearing about an exploded battery if a dead one was cooked on a charger, or some bone head reversed jumper cables when boosting one.
Never remember until the past few years hearing folks say it just blew up while driving, or starting, etc. But I can recall at least five from folks outside here right now, most while starting the car, one while downshifting at a light. Interesting that they are all muscle cars from the late 60's early 70's. But they are a mix of GM, Dodge/Chrysler and Fords so can't say its a particular charging system, I blame the batteries. A quick search here at TC brought up at least 4 with titles Battery exploded!
69-Pace is offline
post #8 of 17 (permalink) Old Aug 19th, 11, 08:44 PM
Michael Gekko
Maybe some of the newer alternators are putting out too much power?
Eleanor's Nemesis is offline
post #9 of 17 (permalink) Old Aug 20th, 11, 04:26 AM
Harry
dawg's Avatar
caps are not vented!
causes hydrogen gas to build until! BANG!!!!!!!!!
(charging batteries make hydrogen gas that needs to be vented)
get a quality battery (maintenance free).
434 stroker
US Navy retired
dawg is offline
post #10 of 17 (permalink) Old Aug 20th, 11, 05:56 AM
Can you believe, that I prevented an elderly neighbour, who was in the process of putting a marine 12V battery in his bedroom closet on a constant charge?!
Seems like he wanted to have a set up for emerg power, with an inverter hooked up to the battery, along with a constant charge going.
I quickly nixed the idea, and refused to put the battery in his bedroom closet, but he still insisted on setting it up in the basement.
I believe, as reinforced by the posts on this thread, that I did right, eh?
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #11 of 17 (permalink) Old Aug 20th, 11, 06:33 AM
Only seen once in person (buddy had his Moms car) pretty uncommon IMO
68 Camaro~LSx ~all motor
post #12 of 17 (permalink) Old Aug 20th, 11, 07:25 AM
Fred
77thor's Avatar
I've never heard of it before...
77thor is offline
post #13 of 17 (permalink) Old Aug 20th, 11, 09:32 AM
chuck
I had the same mishap this summer also. Shut the car down, ran into the store with the kids, came out, turned the key and BAM ! Just like yours. Blew the top of battery into pieces. I even had 2 pieces stuck into the insulation under the hood. Good luck !
chucks69ss is offline
post #14 of 17 (permalink) Old Aug 20th, 11, 09:40 AM
ZaCamaro69's Avatar
Chuck, were you running a maintenance free?
post #15 of 17 (permalink) Old Aug 20th, 11, 11:16 AM
69-Pace's Avatar
Would be interesting if both of you would post the rating - make - and age of your batteries so we can see if they are the same.
69-Pace is offline
