67 total re-wiring info needed - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 15th, 12, 04:57 PM Thread Starter
Joel
joels's Avatar
I am in the process of re-wiring my 67 with the American Autowire kit. It is complete front to back. Iam not using any wiring except what is in the steering column.
Question is, will I need any relays?
The Alt has its internal regulator.
joels is offline
post #2 of 9 (permalink) Old Jan 15th, 12, 05:08 PM
prostreet69camaro's Avatar
Re: 67 total re-wiring info needed
Depends on what you are putting on your car.
Relays:
Horn
Radiator Fans
Electric Fuel Pump
The horn relay might be on the fuse block. I dont know much about the AAW wiring harness.
There are 2 flasher relays, 1 for the blinkers, 1 for the flashers.
prostreet69camaro is offline
post #3 of 9 (permalink) Old Jan 15th, 12, 05:18 PM
topher
69 383 tko 5sp's Avatar
Joel, if you are installing the Classic Update kit, the horn relay(provided in kit) plugs into dash harness pigtail. As Mike said, depends on what you are installing...high amp rad.fan ect.
69 383 tko 5sp is offline
post #4 of 9 (permalink) Old Jan 15th, 12, 05:32 PM Thread Starter
Joel
joels's Avatar
I am just installing a stereo with 4 speakers no amp and later this spring Vintage Air.
joels is offline
post #5 of 9 (permalink) Old Jan 16th, 12, 03:20 AM
The vintage air comes with its own relays.
post #6 of 9 (permalink) Old Jan 16th, 12, 04:21 AM
J.R.
The turn/emergency flasher relays will be installed on the new fuse block in your kit. The kit, if it is AAW's classic update series will have all the needed wiring to hook up your stereo head piece including power antena/batt./ign,etc. Like previously mentioned, your aftermarket AC should have any needed relays supplied with it. So if all your other items were in working order such as heater blower running, etc., you should be good to go. Be sure to clean all ground areas up real good and make sure all grounds are in place. And I am taking it for granted that your car is not a Rally Sport, because there are relays there too. Good luck. J.R.
adjudimo is offline
post #7 of 9 (permalink) Old Jan 16th, 12, 09:36 AM
Michael
Make sure you get the conversion "engine" harness for the 12SI or CS130 alternator (whatever your preference) if you plan to switch from the original remote voltage regulator design.
You can also stipulate between driver's (SWP) and passenger's side (LWP) alternator mounting too.
I'm a big fan of VR elimination and the 12SI for it's durability.
mahunt is offline
post #8 of 9 (permalink) Old Jan 16th, 12, 11:56 AM Thread Starter
Joel
joels's Avatar
My kit came with a wiring harness for the internal ALT. The note in the package said if I was using an external to order part number ########
joels is offline
post #9 of 9 (permalink) Old Jan 16th, 12, 12:31 PM
J.R.
yea, that part is a ballist resistor that you would use for an externally regulated alt. AAW recommends using 10SI, 12SI or a CS130 with their harness. I switched to a 12SI and am very pleased and glad that I did. And also something else to think about: I dont know if your car has factory gauges or not, but if not, and you intend to add aftermarket gauges; you could and in my opinion should keep your early warning (idiot lights) wired up and operable, just for the added protection. They should actually light up before your gauges give warning. Sort of a backup that works first, if you catch my meaning. The AAW info tells you how to do it. J.R.
adjudimo is offline
