1969 Camaro fuse box - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 15th, 12, 12:57 PM Thread Starter
Bill
Have a 69 Camaro (396, set up for AC but not installed) I just bought and the fuse box labels are worn off ; it has 2 vertical banks of fuses, 5 on the right, 3 on the left, one small fuse at the bottom center, with 3 connectors running down the middle (vertically) and one on the bottom left. I need to install a new stereo but it is hard to determine where the accessory and hot leads are. Anyone have any ideas?? I would be thankful for any help.
Bill
Baso is offline
post #2 of 13 (permalink) Old Feb 15th, 12, 02:15 PM
Camarodude67
Re: 1969 Camaro fuse box
I have a picture for you.
Jeff G.
camarodude67 is offline
post #3 of 13 (permalink) Old Feb 15th, 12, 03:19 PM Thread Starter
Bill
That's great! Thanks, how do I get the picture?
Baso is offline
post #4 of 13 (permalink) Old Feb 15th, 12, 03:33 PM Thread Starter
Bill
I can give you my e-mail address if it would be easier.
Baso is offline
post #5 of 13 (permalink) Old Feb 15th, 12, 04:15 PM
Camarodude67
I sent a picture to your e-mail listed in your profile about an hour ago.
Jeff G.
post #6 of 13 (permalink) Old Feb 15th, 12, 05:10 PM Thread Starter
Bill
Got it - That is perfect, thanks so much! Now to figure out why the heater fan and emergency flasher do not work; 99% of the time its the flasher unit, replaced it, still doesn't work. Again, I appreciate the photo.
Baso is offline
post #7 of 13 (permalink) Old Feb 15th, 12, 07:38 PM
ern
ern
check ot see if you have power to the fan switch or to the motor itself ,the orange wire is the wire to the motor, first of all make sure you have power at the fuse, as far as the mergy not working same idea, check fuse first.then power at flasher the one in the fuse box.any other questions ask
ern is offline
post #8 of 13 (permalink) Old Feb 15th, 12, 10:04 PM
There are two flasher units in a 69; the one on the fuse box, and one up under the center of the dash, mounted in a clip on the metal brace between the radio and ashtray. The flasher relay in the fuse box is for the hazard flashers, the one on the underdash brace for the turn signals. I have been staring at the AIM circuit diagrams, and I can't remember if one affects the other. You could also have gotten a defective flasher relay, or have a ground issue.
http://www.ehow.com/how_7517683_test-flasher-relay.html
Eric
Eric Kammerer is offline
post #9 of 13 (permalink) Old Feb 16th, 12, 05:04 PM Thread Starter
Bill
Thanks guys, I fixed the flashers after realizing that the fuse box was missing the flasher unit $6 and it was a done deal; now the turn signals and emergency flashers work, but the indicators in the dash do not. I will tackle the heater blower tomorrow...I hate electrical problems!!
I do appreciate your suggestions though, my experience with Camaros is very limited, had a 66 Chevelle before and there are big differences.
Baso is offline
post #10 of 13 (permalink) Old Feb 16th, 12, 05:19 PM Thread Starter
Bill
Eric - I was just looking at the wiring diagrams and it looks like the turn signal is independent from the ermergency flasher (tracing the lines); I have a really dumb question though, on the diagram it shows two view "A's" on the left side of the page; the upper one is labeled "Fuse Panel" (assuming its the back side of the fuse box) and the lower is labeled "BHD Conn", I dont know what that is, or where it is, thoughts??
Baso is offline
post #11 of 13 (permalink) Old Feb 16th, 12, 06:40 PM
69-Pace's Avatar
Bulkhead Connection
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #12 of 13 (permalink) Old Feb 16th, 12, 06:42 PM Thread Starter
Bill
Many thanks!
Baso is offline
post #13 of 13 (permalink) Old Feb 16th, 12, 11:23 PM
69-Pace's Avatar
You can buy a replacement fuse box without the harness at Lectric Limited. It a custom order so it takes a few weeks.
Or you can buy a silk screen repair kit. You use thinner to remove all the existing labels, apply the screen, spray, dry remove. Think a corvette place still sells them.
69-Pace is offline
