Lost wire that needs a home - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 25th, 12, 11:46 AM Thread Starter
Shane
While trying to figure out why my gen light is always on I came across this
http://www.hotrodders.com/gallery/sh...cat/500/page/1
The wire appears to be brown in color and has a slip type connection. I cant seem to locate where it should go.
If anyone knows let me know. a pic would be helpful Car is a 69
THANKS
stea is offline
post #2 of 7 (permalink) Old Feb 25th, 12, 11:57 AM
Steiner
Re: Lost wire that needs a home
That looks more like the key buzzer wire that plugs onto the horn relay. Try cleaning a little spot and see if it starts to turn pink with a black line.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 7 (permalink) Old Feb 25th, 12, 11:58 AM
69-Pace's Avatar
Shane,
If it is not part of the Voltage Regulator harness it would most likely be not related to your GEN light issue but maybe some accessory item that used to feed from the Horn Relay. Brown wire? maybe it is the drivers side running light connection? How far back can you trace the wire? Pink is the key minder buzzer on the horn relay
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 7 (permalink) Old Feb 25th, 12, 11:59 AM
Guess
HwyStarJoe's Avatar
It plugs into that horn relay on the right side, at the back.
See recent post for location: https://www.camaros.net/forums/showthread.php?t=205529
HwyStarJoe is offline
post #5 of 7 (permalink) Old Feb 25th, 12, 12:03 PM Thread Starter
Shane
Upon closer inspection and cleaning, the wire does appear to be red or pink with a black stripe
stea is offline
post #6 of 7 (permalink) Old Feb 25th, 12, 12:10 PM Thread Starter
Shane
Yep, it was the key buzzer. Plugged it in and found out why the PO had unplugged it.
THANKS GUYS, looks like i need to replace the fusible link on the red wire to the VR. Wire covering is fried.
stea is offline
post #7 of 7 (permalink) Old Feb 25th, 12, 12:12 PM
69-Pace's Avatar
Good deal.
69-Pace is offline
