Under Hood Light Question - Team Camaro Tech
post #1 of 16 (permalink) Old Feb 25th, 12, 05:52 PM Thread Starter
Eric
Can someone tell me what or how the under hood light gets turned on/off on a '69? I'm thinking about adding one to my car and I would like to know what is involved in installing one. Thanks.
L30 327 is offline
post #2 of 16 (permalink) Old Feb 25th, 12, 06:07 PM
Lifetime Gold Member
Drew
ddx77's Avatar
Re: Under Hood Light Question
Mercury switch. Here is an older thread on it - https://www.camaros.net/forums/showthread.php?t=172919
By the looks of it, it's only a positive and negative (ground) connection.
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #3 of 16 (permalink) Old Feb 25th, 12, 07:37 PM
69-Pace's Avatar
yes its the same setup as the trunk lights. Mercury bulb closes the circuit when the hood is open.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 16 (permalink) Old Feb 25th, 12, 09:20 PM
...and kinda like the light in your fridge you assume that it's off when the door is closed.
BPOS is offline
post #5 of 16 (permalink) Old Feb 25th, 12, 09:29 PM
69-Pace's Avatar
Only way to know for sure is to crawl in and close the door.
69-Pace is offline
post #6 of 16 (permalink) Old Feb 26th, 12, 04:52 AM
cb
Send a message via Yahoo to flyingskibiker
Hard excelleration at night could cause a light show!
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #7 of 16 (permalink) Old Feb 26th, 12, 08:01 AM Thread Starter
Eric
Hey , thanks for all of the informative responses. As for mounting the light to the hood,can anyone post a pic. as to which holes to use. I recently installed hood insulation, I guess I will have to pull out a clip or 2, but I'm not sure on the mounting location. Any help would be greatly appreciated.
L30 327 is offline
post #8 of 16 (permalink) Old Feb 26th, 12, 09:38 AM
69-Pace's Avatar
From the AIM
Name:	69 U 26 A1 page 1.jpg
ID:	27184   Click image for larger version
Name:	69 U 26 A1 page 2.jpg
69-Pace is offline
post #9 of 16 (permalink) Old Feb 26th, 12, 10:11 AM Thread Starter
Eric
Thanks ,Brian I have a copy of the AIM,but I couldn't find that part Until I saw your post, Thanks again.
L30 327 is offline
post #10 of 16 (permalink) Old Feb 26th, 12, 10:25 AM Thread Starter
Eric
So, It looks to me like if you have a ZL2 cowl hood you have to drill the holes? My GM hood has no holes in that area at all.
L30 327 is offline
post #11 of 16 (permalink) Old Feb 26th, 12, 11:20 AM
Andrew
Andrew69's Avatar
I purchased the under hood light a few years ago but never installed it because I cannot positively figure out the correct location under my ZL2 hood. Perhaps the formed hood insulation has the correct location blocked off.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 16 (permalink) Old Feb 26th, 12, 12:53 PM Thread Starter
Eric
Well,the AIM pretty much tells you where to drill your holes going off of the insulation fastener hole. So I guess I'll do that when my light comes. Of course it will be LED equipped. LOL.
L30 327 is offline
post #13 of 16 (permalink) Old Feb 26th, 12, 03:37 PM
Andrew
Andrew69's Avatar
My preformed under hood insulation does not utilize that particular hole and masks it. But I can pull the insulation back some and see the hole. Below that is the flat panel that the light would mount to. I was expecting to see some dimples but they are not there.
One day when I have a little time I will mount the light.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #14 of 16 (permalink) Old Feb 26th, 12, 06:55 PM Thread Starter
Eric
Looks like the only dimples I'm gonna see will have to come from my center punch.
L30 327 is offline
post #15 of 16 (permalink) Old Feb 26th, 12, 09:08 PM
69-Pace's Avatar
Since the ZL2 was a mid year addition, no dimples to use. That's why the AIM had "View C" added on Feb 3, '69 and states to use the lamp housing as a template for drilling required holes and has dimensions for placement of the lamp on the hood.
69-Pace is offline
