Can a VR and ignition capacitor be tested with ohm meter - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 26th, 12, 01:27 PM Thread Starter
bigsteve
Can a VR and ignition capacitor be tested with ohm meter to see if they work?
bigsteve is offline
post #2 of 5 (permalink) Old Feb 26th, 12, 04:09 PM
Aaron
BigDawgDavao's Avatar
Re: Can a VR and ignition capacitor be tested with ohm meter
Sort of. You can put the leads on and see if it slowly or quickly builds to maximum (depends on the capacitance rating). Reverse the leads and it should build again. All you can really get is an indication that it's somewhat holding a charge.
BigDawgDavao is offline
post #3 of 5 (permalink) Old Feb 27th, 12, 08:35 AM
What Aaron describes is about the best you can do. Some DMM's have a capacitance checker, but even that is of limited use. Those caps are under severe duty and may check good but fail in circuit. So other than identifying a shorted cap, you just about have to put it in circuit and see if it works.
dnult is offline
post #4 of 5 (permalink) Old Feb 27th, 12, 02:54 PM Thread Starter
bigsteve
bigsteve is offline
post #5 of 5 (permalink) Old Feb 28th, 12, 11:23 AM
One more thought on "ignition capacitors". You're probably talking about the noise suppression cap that attaches to the positive coil terminal. However, if you're talking about the breaker point "condensor", then there are notable symptoms when that cap fails. The engine will run reasonably well at idle, but at higher RPMs it will miss, perform like crap.
dnult is offline
