any idea what the turn signal wire terminals are called - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 27th, 12, 06:31 PM Thread Starter
I cant find them anywhere. The wire terminals on both connectors look the same and slide into each other vs a male and female terminal. I have a engine and light harness in a chevelle with the same terminals and I am trying to clean it up. If only I could find those wire terminals.
wheezer is offline
post #2 of 5 (permalink) Old Feb 27th, 12, 06:51 PM
Rich
Re: any idea what the turn signal wire terminals are called
Which terminals are you asking about? I am just replacing all of the wiring in my Camaro but I have the original harness as well and don't recall any terminals for the turn signals. I have two connectors for the turn signal and parking lamps in the front valence but they are just a standard 2 position connector with the connectors at right angles to each other.
Rich Lordo is offline
post #3 of 5 (permalink) Old Feb 27th, 12, 07:22 PM Thread Starter
the wiring for the turn signals end in terminals inside a connector that looks like the letter C or a cresent moon.
wheezer is offline
post #4 of 5 (permalink) Old Feb 28th, 12, 08:40 AM
GM used a lot of Packard terminals. Could these be them? http://www.madelectrical.com/catalog/flat-blade.shtml
BPOS is offline
post #5 of 5 (permalink) Old Feb 28th, 12, 09:45 AM Thread Starter
Wow, were those hard to find. They are called twin lock terminals. The only place I found them at were www.pcsconnectors.com
wheezer is offline
