Help: where does the negative terminal battery wire ground to ? - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 1st, 12, 07:46 PM Thread Starter
I'm putting my 68 camaro back together after a restoration and I'd like to know where the factory location would be to ground the battery to the chassis.
I am here: http://tapatalk.com/map.php?tejkvc
68 Camaro RS Convertible
Ermin white, black front accent band
Deluxe Interior, power top
Rally wheels
ZZ4 turnkey with TH350
Matching numbers 327 and powerglide stored
All original metal
twalker is offline
post #2 of 13 (permalink) Old Mar 1st, 12, 08:27 PM
Re: Help: where does the negative terminal battery wire ground to ?
There is a special bolt on the water pump. You really should get an Assembly Manual, available from any vender. I rely heavily on mine.
327!275hp!Convt! is offline
post #3 of 13 (permalink) Old Mar 1st, 12, 08:33 PM
Roger
rogerh's Avatar
This is a 67 but I believe the 68s are the same. The smaller wire grounds to the right fender and the engine ground to the top water pump bolt on the rights side.
Roger
rogerh is offline
post #4 of 13 (permalink) Old Mar 2nd, 12, 04:12 AM
1st 67 SS/RS's Avatar
According to the 67 and 68 AIM section UPC 12 page A5 - Roger is correct. Upper water pump bolt on the passenger side.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #5 of 13 (permalink) Old Mar 2nd, 12, 04:42 AM
Roger is also correct that the smaller ground wire from the terminal bolts to the right fender...
U.S Air Force Retired
68 RS/SS, 396 BBC .060 over, M-20, 373 12 Bolt, factory color Island Teal blue, redline bias ply tires.
knuggles68RS/SS is offline
post #6 of 13 (permalink) Old Mar 3rd, 12, 07:01 AM Thread Starter
Guys, thanks a lot - I love this forum, so much help!
I am here: http://tapatalk.com/map.php?opfply
Rally wheels
All original metal
twalker is offline
post #7 of 13 (permalink) Old Oct 6th, 16, 06:32 PM
Jon
Thread resurrection, since I have the exact same question but the factory answer doesn't work for me. My 67 327 doesn't have an exposed stud on the water pump to use for the ground. Am I better off attaching it to the water pump, in between the pump and the AC compressor bracket, or to the thermostat housing?
67 RS, 327/275, PG
Born Sierra Fawn on Gold, now Bolero Red on Gold
Not sure how many owners, but she's mine now...
ScudRunner is offline
post #8 of 13 (permalink) Old Oct 6th, 16, 07:07 PM
If you are not looking for originality, maybe use the bolt blocking off the hole in the front of the block that intersects with the fuel pump push rod hole. Just make sure the bolt is not too long but long enough to keep from pulling the threads when tightening it.
I would clean the surface that the terminal end will be in contact with and then use either an internal or external toothed lock washer also.
Also make sure you attach the small ground wire from the battery post terminal to the fender or radiator support again onto a cleaned spot with a toothed lockwasher.
SOA-Nova is offline
post #9 of 13 (permalink) Old Oct 6th, 16, 07:13 PM
Here's a picture of the hole I was talking about but looking at it, maybe use the one below it instead.
SOA-Nova is offline
post #10 of 13 (permalink) Old Oct 6th, 16, 07:33 PM
'67 with AC connects to a lower bolt on the AC compressor. That's where mine is and is shown in the AIM C60 E2.
1967 RS 327/275hp
trland is offline
post #11 of 13 (permalink) Old Oct 6th, 16, 07:44 PM
Larry
larryh56's Avatar
The best location is directly to the block.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #12 of 13 (permalink) Old Oct 7th, 16, 03:30 AM
This is the best path - shortest route and less electrolysis between fewer parts.
post #13 of 13 (permalink) Old Oct 7th, 16, 06:51 AM
click's Avatar
If not concerned with judges, use the thermostat housing bolt stud
click is offline
