Brown Wire issue?? - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 6th, 12, 08:20 PM Thread Starter
Bucky
Brown Wire issue??
Hey Guys,
Sorry to ask, but I have been through the assembly book wiring detail for about an hour today and am at a dead end?
Where does this brown wire go? It has a "spade" end on it?
Thanks!
http://s867.photobucket.com/albums/a...t=DSC02290.jpg
1967 RS Convert. numbers matching 327/275 with 4 speed hurst on top of a saginaw, 12 bolt 355 rear end, console w/gauges & deluxe int., ORIGINAL PLUM!
Let's Roll!!
imbucky is offline
post #2 of 16 (permalink) Old Mar 6th, 12, 08:26 PM
Re: Brown Wire issue??
Maybe a tach wire ?
SOA-Nova is offline
post #3 of 16 (permalink) Old Mar 6th, 12, 08:35 PM Thread Starter
Bucky
Would it go to the coil?
Let's Roll!!
imbucky is offline
post #4 of 16 (permalink) Old Mar 6th, 12, 09:01 PM
You have a factory tach, correct? Does it work? It looks to be the tach wire which should connect to the negative side of the coil. I have a 68 with a factory tach and that looks exactly like my tach wire.
68BB427 is offline
post #5 of 16 (permalink) Old Mar 8th, 12, 02:39 PM
Gordon
gordr's Avatar
I have a similar situation with a unattached loose brown wire under dash near the park brake.
I've got a tach and gauge setup from Classic Industries and didn't use that wire.
Gordon
gordr is offline
post #6 of 16 (permalink) Old Mar 8th, 12, 06:03 PM
ern
ern
i will check my schematic and let you know tomorrow
ern is offline
post #7 of 16 (permalink) Old Mar 8th, 12, 07:47 PM
69-Pace's Avatar
I vote for the tachometer lead also.
Name:	Firewall Bulkhead Connector - FBC.jpg
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 16 (permalink) Old Mar 8th, 12, 09:11 PM
Gordon
that is probably tan and is the e brake idiot light
Musclerodz is offline
post #9 of 16 (permalink) Old Mar 8th, 12, 09:13 PM
tach should be white. the only brown wire on the engine side of the harness I think is the alternator field wire if you have an SI alternator conversion
post #10 of 16 (permalink) Old Mar 8th, 12, 09:18 PM
Gordon
gordr's Avatar
Hi Mike,
I grounded it with the ignition on and brake light didn't come on... then I grounded the actual master cylinder brown wire and brake light came on.... so I am going to do some checking on that brown wire this weekend as I've been curious now for 3 years since I got the car.....
gordr is offline
post #11 of 16 (permalink) Old Mar 8th, 12, 10:46 PM
cb
Send a message via Yahoo to flyingskibiker
Gordon, does your GEN warning light work?
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #12 of 16 (permalink) Old Mar 8th, 12, 11:23 PM
Gordon
gordr's Avatar
No GEN light in my car as I have gauges and tach...
gordr is offline
post #13 of 16 (permalink) Old Mar 8th, 12, 11:38 PM
cb
Hmmm, I don't own one, but I though '69s still retained the GEN light... Oh well.
post #14 of 16 (permalink) Old Mar 9th, 12, 05:10 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
Brown wire to + coil side
http://www.rclabbe.com/rswiring/rswiring.pdf
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #15 of 16 (permalink) Old Mar 9th, 12, 06:40 AM
cb
Originally Posted by Camaro67_rcl View Post
I have a feeling Bucky solved his Brown wire issue... Now, we are working on the next one!
