"HELP" 69 coupe tail light bulb question - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 9th, 12, 05:09 PM Thread Starter
bigsteve
I have an 1157 bulb in the turn signal Outer socket) and a 1156 in the back up (middle socket) and 1156 in the brake? (Inner socket) on 69 coupe, is this correct or should I have another 1157 somewhere
bigsteve is offline
post #2 of 13 (permalink) Old Mar 9th, 12, 05:47 PM
Andrew
Andrew69's Avatar
Re: "HELP" 69 coupe tail light bulb question
I believe you are correct with 2 each 1156 and 1 each 1157 back there.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 13 (permalink) Old Mar 9th, 12, 05:55 PM
1156 bulbs won't fit an 1157 socket and vice versa. 1156 has two low tits and 1157 has a high and a low. Since you just replaced your trunk harness I'll assume it has the correct sockets. RS used 1157 at the outer and inner spots on 69 but obviously no center socket as the B/U light was separate and below the bumper. You're welcome.
BPOS is offline
post #4 of 13 (permalink) Old Mar 9th, 12, 06:09 PM Thread Starter
bigsteve
Just so i'm clear...my 69 standard coupe should have 1157 outer and inner with a 1156 in the center?
bigsteve is offline
post #5 of 13 (permalink) Old Mar 9th, 12, 06:10 PM
No - 1157 outer, 1156 center and inner for standard non-RS. Not to confuse - but RS got 1157 outer and inner - nothing center. Look closely at your sockets and the "tit" arrangement and install the appropriate bulbs.
BPOS is offline
post #6 of 13 (permalink) Old Mar 9th, 12, 06:23 PM Thread Starter
bigsteve
Then I have the bulbs intsalled correct....
bigsteve is offline
post #7 of 13 (permalink) Old Mar 9th, 12, 06:32 PM
DOH - an even easier way to tell is to look at the number of wires going into each socket - the 1157 will have three - two hots - one for each filament - and a ground. The 1156 will have two wires - a hot for the single filament and a ground.
BPOS is offline
post #8 of 13 (permalink) Old Mar 9th, 12, 06:42 PM Thread Starter
bigsteve
I did but the bulb charts on the site were a little confusing to me
Parking light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1157
Tail light
1157
Stop light
1157
License plate
1155
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
bigsteve is offline
post #9 of 13 (permalink) Old Mar 9th, 12, 06:53 PM
1157 has two filaments. For example, front park lights use one filament for the paklights, the other filament for turn sigs.
1156 has one filament .
On a 69 Camaro - since the sockets are mounted in plastic as opposed to the inferior earlier models which used the metal housing as a ground - they also have their own ground wires. A single ground services both filaments.
Do a google for 1155 bulb - not familiar with it.
As I recall the 69 camaro front 1157 is amber color - probably a slightly different #
BPOS is offline
post #10 of 13 (permalink) Old Mar 10th, 12, 04:32 AM Thread Starter
bigsteve
Yes, its an 1157A
bigsteve is offline
post #11 of 13 (permalink) Old Mar 10th, 12, 04:37 AM
Andrew
Andrew69's Avatar
The chart is in error. It tripped me up too a few years ago.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 13 (permalink) Old Mar 10th, 12, 07:59 AM
Jeff
yellow69RS's Avatar
I wont say the chart is in error but it is confusing. In the front there is only one bulb for the two different functions, in the rear outer there is one bulb for three functions. the portion of the chart quoted here apparently doesn't address the innner socket or the difference between standard and RS.
Jeff
yellow69RS is offline
post #13 of 13 (permalink) Old Mar 10th, 12, 10:25 AM Thread Starter
bigsteve
Thanks for your support! I think is trying to show the difference between the 2 models without writing it down.
Today I cleaned the dash light fuse holder and the connector to the light switch and now the parking lights and dash lights are working again!!!!! one thing I did notice is that the 30 amp fuse holder i'm running from positive battery cable to junction block has a little melt look going on and I cant seperate the 2 sections to get the fuse out.
bigsteve is offline
