And So It Begins... - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 12th, 12, 04:04 AM Thread Starter
And So It Begins...
Wired up the entire car. Everything new, everything. Everything works... except the RS headlight doors of course. Nothing, nada. zilch. I start the troubleshooting process tonight. I was too tired to go any further lol. Please bear with me as I cuss, fight and trudge through this. Hope its something easy.
67 With a few things bolted to it
98 Z28 That needs love
12 SS With a few things bolted to it
50 Chevy With a few things unbolted from it
RJ USAF
AintQik is offline
post #2 of 14 (permalink) Old Mar 12th, 12, 05:21 AM
prostreet69camaro's Avatar
Re: And So It Begins...
Vacuum or electric headlights??
prostreet69camaro is offline
post #3 of 14 (permalink) Old Mar 12th, 12, 07:23 AM Thread Starter
Electric. All new stuff. All the relays are new. The dash is getting power because everything works inside. Light switch is working, at least partially, because gauges all illuminate. It's new as well. I will troubleshoot tonight and document my progress and see what you guys say. I was hoping this was going to be easy lol.
RJ USAF
AintQik is offline
post #4 of 14 (permalink) Old Mar 12th, 12, 07:25 AM
Bill
Calpantera's Avatar
Ha! You wish
Calpantera is offline
post #5 of 14 (permalink) Old Mar 12th, 12, 07:48 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
headlight harness for RS ?
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #6 of 14 (permalink) Old Mar 12th, 12, 08:17 AM
Eric
Depthrecordings's Avatar
Found this: https://www.camaros.net/forums/showthread.php?t=151851
This is something I will be doing here soon. I actually had a nightmare about it last night. LOL
I hope you get your issue worked out. I'm sure if you got this far it should be an easy fix.
What harness did you go with?
Eric.B
Denver, CO
1967 Camaro
Depthrecordings is offline
post #7 of 14 (permalink) Old Mar 12th, 12, 08:41 AM
Kevin
KevinW's Avatar
RJ, make sure all grounds are good, clean and ohm out. Many an electrical issue is traced to freshly painted items in which the paint film prevents the grounds to flow.
Kevin
KevinW is online now
post #8 of 14 (permalink) Old Mar 12th, 12, 08:56 AM Thread Starter
Yes, correct M&H RS harness. Everything is there... I think lol. Is there anything in the interior of the car besides the headlight switch that powers the headlight motors? The reason I ask is because there are 3 wires unaccounted for under the dash. 1-I'm pretty sure is the wiper switch (I went with DSE wiper which includes new stand-alone wiper harness), 2-is a brown and blue which goes to a harness going back (back-up lights I think), 3-I have no idea. Probably a radio feed mine is a radio delete car and I kept it that way.
In my wire harness from M&H there was a seperate package with a blue and brown wire, about a foot long that was labeled, "RS under dash extension". I can only guess that goes to the back up light harness but the dash end has a bunch of brown wires and plugs on them I have yet to figure out.
Having said all that, I don't think any of that has anything to do with the door motor circuit. I will get to that later. Other than that its all hooked up. I'm at work, so just trying to arm myself with some knowledge to get started t-shooting when I get home. I do have the RS schematic.
Kevin, so far I've checked a bunch of the related grounds and they ohm out good.
RJ USAF
AintQik is offline
post #9 of 14 (permalink) Old Mar 12th, 12, 09:49 AM
Bill
Calpantera's Avatar
I have used M&H in the past and their support is top notch. I would give them a call about the RS extension wires as well as ask if there might be anyhting obvious that you might have missed.
post #10 of 14 (permalink) Old Mar 12th, 12, 11:30 AM Thread Starter
Bill for the win.... I think.
I called M&H and after 34 minutes of holding I got a very well educated tech. The "extension harness" I have been babbling about is supposed to be jumpered in to the headlight and ignition switch. It works both the parking lights and the headlight motors. So... I will try this tonight and let you all know how I make out.
RJ USAF
AintQik is offline
post #11 of 14 (permalink) Old Mar 12th, 12, 11:35 AM
Bill
Calpantera's Avatar
Nice..
post #12 of 14 (permalink) Old Mar 12th, 12, 06:11 PM Thread Starter
Wired up and they opened. Now just need to re check grounds. It was that extension.
RJ USAF
AintQik is offline
post #13 of 14 (permalink) Old Mar 12th, 12, 06:35 PM
Bill
Calpantera's Avatar
Sweet! One step closer RJ!
post #14 of 14 (permalink) Old Mar 13th, 12, 08:58 AM
Michael
Without the underdash diode extenstion, what did you hook up your RS firewall passthrough to?
mahunt is offline
