69 Hazard Light Button Issue - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 15th, 12, 09:34 AM Thread Starter
69-Pace's Avatar
Exclamation 69 Hazard Light Button Issue
My Hazard Switch is malfunctioning:
Left & Right turn signal indicators work.
Front and back turn lights blink.
I even swapped the flasher unit between signals and hazards with no change so the issue is the button.
Hazard switch started to pop out on its own last year and now most of the time won't lock in the depressed "on" position.
Also now even if you can get the button to lock or you hold it by hand, the right indicator on the dash won't light or flash, but the front & rear left and right lights are flashing.
So I assume that the hazard switch needs to be removed and replaced. Don't think I can service from outside column. I hate steering column work so I want to make sure I don't miss anything in replacing the switch. Anyone have any good pictures of this job?
I think I will need to do the following looking at the AIM:
Pull the wheel
Pull the horn button guts
Pull the turn signal cancel cam.
Now is where I'm worrying. Never been deeper then this so what are the next parts to come out - ignition switch or can that stay in?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #2 of 10 (permalink) Old Mar 15th, 12, 09:46 AM
Guess
HwyStarJoe's Avatar
Re: 69 Hazard Light Button Issue
Ignition switch can stay.
You're right that the turn signal cam has to come out... it's also the hazard switch.
When you press down on on the hazard button, there's a curved flat spring that depresses and makes the button pop back up. The button itself is attached to a square black plastic piece that 'snaps' in or out, depending on whether you push or pull the button. That piece is probably you're problem.
HwyStarJoe is offline
post #3 of 10 (permalink) Old Mar 15th, 12, 09:59 AM Thread Starter
69-Pace's Avatar
Joe so if that part is the issue, I have to replace the turn signal cam. Are the reproduction prone to any fitment issues?
And am I right in assuming that if the turn signal wiring is fine, turn signal indicator works, that the hazard switch uses the same connection and its just that the "spring" is not contacting all the leads at the hazard switch part or may I still have a wiring issue on the hazard side.
69-Pace is offline
post #4 of 10 (permalink) Old Mar 15th, 12, 10:22 AM
Jeff
yellow69RS's Avatar
The Hazard switch is part of the turn signal switch, not the cam. I'm sure that's what Joe menat to say needs to be replaced. The T/S switch is all the deeper you need to go but you have to undo the column mount bracket at the dash to get the wires thru.
Jeff
yellow69RS is offline
post #5 of 10 (permalink) Old Mar 15th, 12, 11:17 AM
Guess
HwyStarJoe's Avatar
That's what I meant.
It's possible to have a wiring issue... I'll bet the wires are all dried and cracked at the switch. The factory puts some serious bends in the harness which doesn't help matters.
You'll see what we're talking about once you get the steering wheel off and the rest of the upper column parts.
Here's Jim Shea's Steering Papers, all about the column and parts break-downs with pictures: http://jimshea.corvettefaq.com/?cat=4
post #6 of 10 (permalink) Old Mar 15th, 12, 02:13 PM Thread Starter
69-Pace's Avatar
Okay if I can find my wheel pull I'll dig into it this weekend. Thanks.
69-Pace is offline
post #7 of 10 (permalink) Old Mar 15th, 12, 06:07 PM
Visit Harbour Freight, both the wheel puller and lock ring plate pusher for under $20(?), maybe $10.
I bought the pusher for $2 and worth every penny of it. Use a scribe to remove the retaining ring.
post #8 of 10 (permalink) Old Mar 18th, 12, 08:23 AM Thread Starter
69-Pace's Avatar
Thanks Everett - Think I loaned mine out a few years ago and it never returned to my tool box for some reason. Guess the price is right.
69-Pace is offline
post #9 of 10 (permalink) Old Mar 18th, 12, 06:54 PM
prostreet69camaro's Avatar
When you pull the wiring plug thru you're column tape a piece of wire to it for a pull wire to pull the new plug thru.
prostreet69camaro is offline
post #10 of 10 (permalink) Old Mar 18th, 12, 09:50 PM Thread Starter
69-Pace's Avatar
Thanks Mike for the tip
69-Pace is offline
