New Cig. lighter blowing 25a fuse - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 15th, 12, 07:49 PM Thread Starter
J.R.
Just received a new lighter assembly for the 67 and received all three pieces. Installed and hooked up orange wire to back side and blew fuse. Second 25 amp fuse blew as well. Stumped as to why I would be blowing fuses and the only power wire connects to the one pin connector on the rear of assembly. using new AAW Classic update wiring harness. Any thoughts?
adjudimo is offline
post #2 of 6 (permalink) Old Mar 15th, 12, 08:21 PM
Roger
rogerh's Avatar
Re: New Cig. lighter blowing 25a fuse
Dose it blow the fuse with the lighter out of the socket? Dose it blow the fuse with lighter in the socket but not pushed in? Dose it blow the fuse only after you push in on the lighter?
Roger
rogerh is online now
post #3 of 6 (permalink) Old Mar 15th, 12, 09:05 PM
Steiner
Possibly one of the tangs down inside the receptacle from the 12V line is touching the inside of the barrel. I poked around in mine once with my finger and made the fuse pop when one of them flexed over.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 6 (permalink) Old Mar 16th, 12, 02:05 AM Thread Starter
J.R.
Been away for a bit. I'll check things out a bit and let you know what I find sometime tomorrow evening. I need to pick up some extra fuses.
adjudimo is offline
post #5 of 6 (permalink) Old Mar 17th, 12, 03:54 AM Thread Starter
J.R.
I took the lighter assembly back out for the third time and finally found a very small stray piece of metal shaving lodged inside, I quess from manufacturing and it was causing the lighter to short out. Air compressor, tweezers and a small magnet took care of it. It was caught between one of the tangs and the outer wall way in the back/bottom. Lighter is now working properly. Thanks for your imput.
adjudimo is offline
post #6 of 6 (permalink) Old Mar 18th, 12, 07:45 PM
cb
Send a message via Yahoo to flyingskibiker
Thanks for posting your results! And good catch!
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
