Back up lights not working. - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 16th, 12, 09:31 AM Thread Starter
Dean
islanddean's Avatar
I've replaced the light bulbs and neutral safety switch but the lights won't come on when I place the car in reverse. Any idea?
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 7 (permalink) Old Mar 16th, 12, 09:56 AM
69-Pace's Avatar
Re: Back up lights not working.
Dean - The reverse backup switch on 67 and 68 is on the shifter or on the auto trans case. 69's because of the new ignition lockout uses a switch in the column by default.
So what are you running for a tranny? Manual or Auto?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 7 (permalink) Old Mar 16th, 12, 10:33 AM Thread Starter
Dean
islanddean's Avatar
I have a TH350 tranny...automatic.
MLK
post #4 of 7 (permalink) Old Mar 16th, 12, 12:47 PM
Fuse?
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Z28 intake, FAST-EZ EFI 2.0, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi
LukeWarm is offline
post #5 of 7 (permalink) Old Mar 16th, 12, 01:07 PM Thread Starter
Dean
islanddean's Avatar
Installed a new fuse yesterday. I'm hoping this is a cheap fix as I'm not looking forward to purchasing a new wiring harness..the wife is already asking me how much more I plan to spend. Let's see....how long can I go without sex? Hmmmmmm.
MLK
post #6 of 7 (permalink) Old Mar 16th, 12, 02:52 PM
With a '67 and a console, b-up switch will be on the pass side of the shifter.
Pink is power from the fuse panel.
Light green out to the bulbs.
Ignition power for source.
If no console, then look for a female two-wire receptacle next to the pedal on the engine side of firewall. There should be also a male plug and harness going to a switch maybe under the shifter.
post #7 of 7 (permalink) Old Mar 16th, 12, 07:46 PM
cb
Send a message via Yahoo to flyingskibiker
You might also want to try jumpering the wires at the back-up then turn the key on to see if the lights go on. If so, it's something to do with the switch (bad or aligned wrong). If not, it is most likely wiring, fuse, or grounds.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
