Gas Guage Issue - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 16th, 12, 05:24 PM Thread Starter
Jeff
Gas Guage Issue
Gas guage is almost on full. Sending unit ohms are within range (0-90) have continuity to the fuel gauge. When I ground the tan wire to the sending unit the guage doesn't move. NO isuues with ground. I am totally perplexed!! WTF
jeffscamaro is offline
post #2 of 11 (permalink) Old Mar 16th, 12, 05:41 PM
Steiner
Re: Gas Guage Issue
Do you have the key on when doing this?
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 11 (permalink) Old Mar 16th, 12, 05:56 PM Thread Starter
Jeff
Re: Gas Guage Issue
When checking ohms-no when grounding the tan wire-yes.
post #4 of 11 (permalink) Old Mar 16th, 12, 06:03 PM
Re: Gas Guage Issue
If ground is on the tan wire, the gauge should go to empty.
No empty, bad gauge.
post #5 of 11 (permalink) Old Mar 16th, 12, 06:11 PM Thread Starter
Jeff
Re: Gas Guage Issue
If I'm reading ohms from the guage does this still mean its defective or could it be the guage resistor?? How would I test that?? are there perameters for this??
post #6 of 11 (permalink) Old Mar 16th, 12, 06:29 PM
69-Pace's Avatar
Re: Gas Guage Issue
Yes you can test the resistor using your meter.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 11 (permalink) Old Mar 16th, 12, 06:38 PM Thread Starter
Jeff
Re: Gas Guage Issue
what range of resistance would I get?
post #8 of 11 (permalink) Old Mar 16th, 12, 06:54 PM
69-Pace's Avatar
Re: Gas Guage Issue
If you are running an AC-Delco factory fuel gauge you might have an OEM (thin wire wound around fiber or plastic board) style resistor and it should read aprox 40 ohms plus or minus a few.
If you have a replacement OER fuel gauge there is no resistor - its built in.
If you are running a Classic HQ reproduction fuel gauge you need either an original style wire resistor or a replacement style "shunt" made of ceramic material.
Ceramics are 45 ohms,
69-Pace is offline
post #9 of 11 (permalink) Old Mar 16th, 12, 06:57 PM Thread Starter
Jeff
Re: Gas Guage Issue
Awesome you rock!! Thank You
post #10 of 11 (permalink) Old Mar 16th, 12, 08:43 PM
Re: Gas Guage Issue
Take a look at my thread about the gauge. I had some crazy problems, and my post has every single way to troubleshoot. Go to my profile and find the thread.
Camaro108 is offline
post #11 of 11 (permalink) Old Mar 16th, 12, 08:50 PM
Re: Gas Guage Issue
https://www.camaros.net/forums/showth...24#post1679224
Heres the thread!
