New vintage gauges. I'm having trouble - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 17th, 12, 03:49 AM Thread Starter
Robert
I just installed my new vintage gauges in my 67 convertible. I'm having troubles. The tach jumps all over the place when cruising but not under load. The speedo won't calibrate I can get it into set mode after 2-3 try's but after my mile drive it won't set when I hit the button again. The lights don't come on together and at night one or both may go out for a second or two. I've checked all my connections, all my wires are crimped, gauges are grounded behind the cluster directly to the body with a sheet metal screw and the paint is scrubbed off. I feel like everything is connected solid.
Any ideas before I call new vintage?
hosspala is offline
post #2 of 5 (permalink) Old Mar 17th, 12, 10:08 AM
topher
69 383 tko 5sp's Avatar
Re: New vintage gauges. I'm having trouble
I assume you purchased the correct senders from NV. Was thinking of going with the 69 type from NV, so I am subscribing to this thread. Please keep us posted of outcome. Good luck.
69 383 tko 5sp is offline
post #3 of 5 (permalink) Old Mar 19th, 12, 06:47 PM Thread Starter
Robert
All the senders but the speedo came with the gauges. The speedo sender was purchased separatly but it is new vintage brand. I got everything from summit racing
hosspala is offline
post #4 of 5 (permalink) Old Mar 19th, 12, 08:28 PM
topher
Just to be sure you have a good ground, you might try a grounding washer or star washer if you have not already done so.
post #5 of 5 (permalink) Old Mar 20th, 12, 11:00 AM
Russ
One more comment on grounding, make sure the chassis has a good ground to the motor and the battery. If your ground between the chassis and the battery sucks then no matter what you do under the dash it won't help.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
