SPAL fan Relay wiring - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 20th, 12, 03:59 AM Thread Starter
Harry
dawg's Avatar
I got the fan pretty much wired but im looking for the best spot to tie in the igniton wire somewhere?
(on when engine is running)
relay is located next to battery on passenger radiator support.
grounds are hooked up, +12volts hooked to the battery.
434 stroker
US Navy retired
dawg is offline
post #2 of 13 (permalink) Old Mar 20th, 12, 04:01 AM
Re: SPAL fan Relay wiring
I'd run it to the fuse panel.
An honest man's pillow is his peace of mind. JCM
family man is offline
post #3 of 13 (permalink) Old Mar 20th, 12, 06:20 AM
I agree, either the ACC or IGN spades of the fuse panel.
post #4 of 13 (permalink) Old Mar 20th, 12, 06:36 AM
This thread has a picture of the fuse panel and you can see how someone has tapped off it it to feed some accesories.
https://www.camaros.net/forums/showthread.php?t=194089
post #5 of 13 (permalink) Old Mar 20th, 12, 06:47 AM Thread Starter
Harry
dawg's Avatar
doesnt the horn relay connections work aswell???
I was trying to not have to punch a new hole in the firewall to run another wire?
_
434 stroker
US Navy retired
dawg is offline
post #6 of 13 (permalink) Old Mar 20th, 12, 08:10 AM
Horn relay has battery power to it all the time, regardless of function.
If you have an automatic, you can remove the clutch rod plate from the firewall and either cut & grommet a hole in the plate or get/make a new plate and do the same.
post #7 of 13 (permalink) Old Mar 20th, 12, 08:55 AM Thread Starter
Harry
dawg's Avatar
hmm what about starter solenoid connections?????
gotta be an ign or acc terninal somewhere in the engine bay other than the coil?
434 stroker
US Navy retired
dawg is offline
post #8 of 13 (permalink) Old Mar 20th, 12, 09:36 AM
Greg
_
You can't sqeeze 1 more wire through an existing hole in the firewall? A relay wire is very small.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #9 of 13 (permalink) Old Mar 20th, 12, 09:39 AM
Guess
HwyStarJoe's Avatar
That's what I did. Drilled a hole in the plate and added a grommet. I've got several things going through there.
HwyStarJoe is offline
post #10 of 13 (permalink) Old Mar 20th, 12, 09:59 AM
Bill
Calpantera's Avatar
Should the relay actually be on a switched source? I know I have seen factory fans that still cool the rad after the engine is turned off. Or is that just a waste being that the engine is not running anyway?
Calpantera is offline
post #11 of 13 (permalink) Old Mar 20th, 12, 10:09 AM
The relay power goes through a temperature switch and when the temp sw is satisfied, sw opens, fan goes off.
Depends on where temp sw is located. Some OEM's have the temp sw monitoring rad outlet tank coolant temp, HVAC high side pressure, or engine compartment temp.
post #12 of 13 (permalink) Old Mar 20th, 12, 10:22 AM
Marc
mnm99's Avatar
Are you going to have it run all the time? I have mine on a Dakota digital and LOVE it. 4 years so far , no problems. One fan comes on at 185 and the other at 195. My second fan hardly ever comes on and thats with a twin turbo setup under the hood..
http://www.dakotadigital.com/index.c...rod/prd641.htm
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #13 of 13 (permalink) Old Mar 20th, 12, 03:59 PM Thread Starter
Harry
dawg's Avatar
no ill have it come on with the temp switch.
But ill install an override switch aswell.
434 stroker
US Navy retired
dawg is offline
