Passenger side alternator mount - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 21st, 12, 09:16 AM Thread Starter
Ben
Does anyone know if you have to use the short or long water pump to re-locate the alternator to the passenger side on a 67 ? Or does it matter at all ?
Big Ben
1967 Camaro
1980 Z/28 all original
original owner
2011 2SS/RS Camaro 6speed/manual
BigBen is offline
post #2 of 8 (permalink) Old Mar 21st, 12, 10:18 AM
Camarodude67
Re: passenger side alternator mount
Why would you move it to the passenger side? 67 and 68 are on the driver side.
Jeff G.
69 Verts
69 Z/28
70 454 Chevelle Convertible
camarodude67 is offline
post #3 of 8 (permalink) Old Mar 21st, 12, 10:34 AM
You would have to use a long water pump AND pulleys, both W/P and crank, going along with the LWP.
Don't forget the pass side brackets also.
post #4 of 8 (permalink) Old Mar 21st, 12, 12:10 PM
Michael
And the bolt hole in the passenger side head that anchors the bottom alternator mount.
mahunt is offline
post #5 of 8 (permalink) Old Mar 21st, 12, 07:00 PM Thread Starter
Ben
So youre saying its not worth it?
Big Ben
1967 Camaro
original owner
BigBen is offline
post #6 of 8 (permalink) Old Mar 21st, 12, 07:19 PM
Sean
The short pump can be either and so can the long if using aftermarket brackets.
This has been a pia for me lately since I need to go with a LWP on my new mill, and you have less options with a long pump. Almost any mfg makes a mount for both sides and a short pump, you are pretty limited with a long version.
I wish I could use a short pump but it won't work in my case, it's been a pain finding performance oriented long pump accessory drive stuff, unless you are into billet and shiny bling, which I am not.
Why are you going to go pass mount? In my case I need to for the blower, otherwise I would leave it DR side and get performance brackets and pulleys.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 8 (permalink) Old Mar 22nd, 12, 04:17 AM
Guess
HwyStarJoe's Avatar
Re: Passenger side alternator mount
Sure it's worth it if that's what you want to do. Pulleys are a dime a dozen.
I wish I could remember who I got it from, but I bought a special bracket to mount the Alt. because I don't have accessory holes in the heads. It was already on the passenger side to begin with though, so I already have the long water pump and correct pulley.
Someone makes the bottom rear bracket to mount the alternator off of the water pump. I just don't remember who it is.
HwyStarJoe is offline
post #8 of 8 (permalink) Old Mar 22nd, 12, 03:50 PM
If you don't want chrome brackets just get some and sandblast/paint satin black works well.
69 Pace Car and 69 Hard top
srode is offline
