68 Camaro console temp gauge question - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 24th, 12, 04:06 AM Thread Starter
tyrfryrtom's Avatar
I am installing console gauges in my 68 Camaro. All new wiring and new gauge package. The temp gauge pegs "c" when you turn key on. But seems to show temp when key is off. I have tried adding another ground but that didn't help.
Has anyone else run into this?
tyrfryrtom is offline
post #2 of 3 (permalink) Old Mar 24th, 12, 09:50 PM
Vic
cadmanof50s's Avatar
Send a message via Yahoo to cadmanof50s
Re: 68 Camaro console temp gauge question
Hi Tom,
It pegs to the Cold side? When you ground the connector at the temp sending unit, you should get a full HOT deflection. If not....and it pegs to full cold, I would say you have the temp gage wires reversed.
Vic
Vic Brincat
383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs
cadmanof50s is offline
post #3 of 3 (permalink) Old Mar 25th, 12, 06:16 PM
Daniel
You need to disconnect the wire that is going to the Temp Light. I had the same issue on my 69, it was pegging when the light was turned on when starting the engine. Mine was also acting up when the car engine was running. Good luck.
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
FBODY is offline
