pertronix upgrade on a 73 cam - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 25th, 12, 06:59 PM Thread Starter
RICK
i know this is not a first gen ? but i installed a pertronix ignition upgrade on the wifes 73 rs and need to know which wire on the steering column harness is the ignition wire. i have it run to the ignition port onthe fuse block but i want to run it directly off the ignition wire to make sure that i,m getting a full 12 volts. thanks for the help rick
rbs67cam is offline
post #2 of 2 (permalink) Old Mar 25th, 12, 08:23 PM
Re: pertronix upgrade on a 73 cam
You will get the same full 12 volts from the fuse block ignition terminal.
reelknots is offline
