69 327 battery ground at radiator hose water neck - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 12, 01:34 PM Thread Starter
bigsteve
If I pull the water neck stud to wire wheel it can I use never seize or die electrical grease to keep it from corroding or will it interfere with the grounding?
bigsteve is offline
post #2 of 4 (permalink) Old Mar 28th, 12, 04:11 PM
69-Pace's Avatar
Re: 69 327 battery ground at radiator hose water neck
Dielectric grease is a conductor so that should be okay.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Mar 28th, 12, 06:40 PM
Dielectric grease is a non-conductive, silicone grease designed to seal out moisture and, therefore, prevent corrosion on electrical connectors. Being non-conductive, it does not enhance the flow of electrical current. This property makes it an ideal lubricant and sealant for the rubber portions of electrical connectors.
Dielectric grease is typically a translucent, grey substance that is insoluble in substances such as ethanol, methanol, mineral oil, and water. It is soluble, however, in the industrial solvent methyl ethyl ketone (MEK) and mineral spirit. It is important to note dielectric grease will melt silicone rubber over time, and thus should not be used on connectors, such as o-rings, made of this rubber.
While the indicated use of dielectric grease calls for it to be used only on the non-metal parts of a connection, it has been shown to be effective at preventing corrosion when applied directly to the metal connectors as well. Care should be taken when using it in this way, because this application can, in some instances, cause the connection to stop working. A common reason for such a failure is the grease has not been pushed entirely out of the way between the two points of contact.
Use a few drops of engine oil from the dipstick or a squirt of 3 in 1 oil on the threads.
Wipe off excess. Personally, I would bolt the battery cable to the block, like the fuel pump rod bolt boss, bolt is already there, add a star washer between the cable and block.
post #4 of 4 (permalink) Old Mar 28th, 12, 08:51 PM
Steps
Think about it...a bit of sealant on the threads......that gets squished into the microsopic gaps between the threads when it is torqued up...there is still a huge amount of steel to steel contact....even thread tape on a temp thermostat...if used correctly never an issue...BUT if u wind on layer after layer...which is NOT how the stuff is used.... yeah u could have an issue
Steptoe is offline
